Driving on Ice
Discussion in '5th Gen 4Runners (2010-2024)' started by mbelleville, Dec 20, 2024.
  1. Dec 20, 2024 at 6:39 PM
    mbelleville
    mbelleville [OP] New Member
    I'm new to my 2011 4Runner. Are there any features that are helpful for driving on icy roads beyond the 4 wheel drive?
    Shredder likes this.
  2. Dec 20, 2024 at 6:52 PM
    icebear Recovered Kia Owner
    A-TRAC will be helpful in situations where a wheel on one side has more traction than another.
    Turning traction control off may be helpful in situations where wheels need to spin more.
    This is also handy:
    Toy4X4 likes this.
  3. Dec 20, 2024 at 6:52 PM
    Shredder
    Shredder New Member
    Traction control can help, but 4hi is your best friend. And remember 4wd doesn't mean you can stop quicker.
    Mully410, Noodles, Toy4X4 and 3 others like this.
  4. Dec 20, 2024 at 6:58 PM
    Imdav2u
    23 TRD PRO
    Crawl control got me out of a couple icy situations with my truck.
    Mully410 and Toy4X4 like this.
  5. Dec 20, 2024 at 7:10 PM
    mbelleville
    What is crawl control and how do I activate it
  6. Dec 20, 2024 at 7:14 PM
  7. Dec 20, 2024 at 7:15 PM
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    Snow tires with or without studs, chains
    2ndGen22re and 3JOH22A like this.
  8. Dec 20, 2024 at 7:18 PM
    What model 4Runner do you have? The Trail Edition is the only one that had crawl control in the 2011 model year.
    Beyond that, drive carefully, use four high when it's icy, and like others have said, just remember that 4wd does not help you stop any better.
  9. Dec 20, 2024 at 7:35 PM
    About that...
  10. Dec 20, 2024 at 9:16 PM
    If you drive a lot in snow and ice get a set of winter tires. It’s a night and day difference in traction compared to everything else.
    Toy4X4 and Trail Runnah like this.
  11. Dec 20, 2024 at 11:23 PM
    If you’re talking about solid glare ice…then dedicated snow tires will be your best friends. Traction control and the vehicle stability system can do lots of great stuff, but they need some sort of traction to work.
    Personally, I’ve noticed the 4runner ABS can be more flakey when traction is nearly nil than other cars I’ve owned. At very slow speed (like below 5mph) on very slippery conditions (like glazed ice), it will sometimes completely release all braking pressure and give up the tiny bit of traction you do have. The result can be rolling through an intersection at 2mph with all 4 tires turning. Push harder on the brakes, and the ABS releases even more braking pressure.
    That doesn’t always happen, but whenever I’m on ice, I’ve learned to be very light on the brake pedal to avoid ABS activation. Once it activates , it can surprise you when it’s no longer slowing down like was before it activated. In fact, the only way to recover is to treat the brake pedal like an old-school non-abs system…release the brake pedal, and gently apply super light pressure. If abs activates again, release the pedal, and gently apply again. 2mph doesnt sound bad, but it sucks when you don’t want to fall off the road or hit something.
  12. Dec 21, 2024 at 4:36 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    If you regularly drive on ice, #1 step is to get a set of dedicated winter tires.
    Rocko9999 and Noodles like this.
  13. Dec 21, 2024 at 9:37 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    If it's true solid ice, drive with the passenger side wheels off the edge of the ice in the snow.
    Trail Runnah likes this.
  14. Dec 21, 2024 at 11:23 AM
    mbelleville
    That was exactly my experience yesterday. I was going VERY slow down a hill approaching the intersection, There was only about an inch of snow and ice at the point but I had very little control
  15. Dec 21, 2024 at 1:14 PM
  16. Dec 21, 2024 at 2:14 PM
    Shredder
    Shredder New Member
    I was wrong, I learned something, lol. My point, although without factual basis was that driving in 4hi on snow and some ice seems easy, but braking is affected, and it can surprise you when your sliding wildly. My very best snow car was a 79 olds tornado, I was driving a ton back then in my job and driving it in snow was no problem and it could make you complacent driving it, but it was hard to stop quickly on snow or ice being a relatively heavy car.
    3JOH22A[QUOTED] likes this.
  17. Dec 21, 2024 at 2:15 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    You would have had better control if there had been 4" of snow on that ice. I can't imagine worse conditions than 1' or less snow on top of ice with the exception of rain on ice.
  18. Dec 21, 2024 at 2:16 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    The most important feature for driving in icy conditions is the one located between your ears, followed by the ones located at the ends of your arms and legs.
    It’s not so much about the vehicle as it is exercising proper judgment and smooth inputs.
    FatChance and Toy4X4 like this.
  19. Dec 21, 2024 at 2:20 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    The loose nut on the steering wheel.
    MEski4x4 and bassist[QUOTED] like this.
  20. Dec 21, 2024 at 5:14 PM
    Yes the improvement in braking with 4WD is about 14% based on the Tacoma video, not night & day. I use a lower gear than usual on snow and ice, and downshift earlier, relying more on engine braking to slow down.
    MEski4x4 and Shredder[QUOTED] like this.
  21. Dec 21, 2024 at 8:04 PM
    BeyondTrails
    BeyondTrails New Member
    jay
    21 4R TRD PRO
    driving on snow pretty straight forward. learn to drive slow, use 4wd, and the different modes. have a set of decent chains and traction boards just in case. now-a-days, mainstream a/t tires are 3PMSF which helps. not everyone has a set of dedicated winter snow tires in their garage to swap out.
    driving on ice is tricky because ice usually wins if you freak out and are not in control. take it real slow, downshift, pump breaks if needed, or pull over somewhere safe haha.
  22. Dec 22, 2024 at 5:22 AM
    You will most likely find on tires that are meant for "winter use", that they have lots of siping on them. Siping is the little sometimes squiggly lines on the tread portion of the tire. The siping makes the tire tread more flexible and acts like more tread surfaces helping grip on icy/snowy condition roads. Also like some stated above, learn to drive slow and smooth input to steering and brakes. Good luck.
  23. Dec 22, 2024 at 7:02 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Living in the South, I don't drive on ice much but I do walk on pins and needles a lot when I'm around the old lady.
    Imdav2u likes this.
  24. Dec 22, 2024 at 7:13 AM
    Imdav2u
    23 TRD PRO
    That's not just a southern thing. Sometimes I wake up grumpy, most days I let her sleep.
    Grandpawmoses[QUOTED] likes this.
  25. Dec 22, 2024 at 7:20 AM
    Or drive like a rally driver and power slide it around the corners. :D
    Shredder and Toy4X4[QUOTED] like this.
  26. Dec 22, 2024 at 8:12 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Great video -thanks for providing.
  27. Dec 22, 2024 at 8:51 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    From someone who grew up in the snow and ice belt....the only REALLY effective traction control on ice is tire chains. On all four tires if conditions are bad enough. Something that actually digs into the ice. Note the spikes sticking up the chains:
    Next best thing is studded snow tires. Again, something that digs into the ice. Winter tires are good but they still can't grip glare ice.
    Toy4X4, Captain Spalding and Imdav2u like this.
  28. Dec 22, 2024 at 9:16 AM
    Imdav2u
    23 TRD PRO
    Check your states laws, studded snow tires are illegal in The Peoples Republic of Illinois and most states have restrictions on when you can use them.
    Toy4X4 likes this.
  29. Dec 22, 2024 at 9:31 AM
    bassist
    bassist New Member
    In most of the upper Midwest, there’s enough road salt put down to make those pointless anyway.
    Shredder and Toy4X4 like this.
  30. Dec 22, 2024 at 9:46 AM
    Charlievee
    Charlievee Not new member.
    I'm sure the Toyota nanny assist brake system can't help. Crap locks up the brakes on dry pavement, all it takes is moving your foot to quickly from the go peddle to the stopper and your sitting 60 feet away from a red light with anything not tied down flying forward.
