Drives in Neutral, Parks in Reverse
Discussion in '2nd Gen 4Runners (1990-1995)' started by Mike557, Feb 4, 2019.
  1. Feb 4, 2019 at 12:03 PM
    Mike557
    Mike557 [OP] New Member
    92 4runner
    Hello I recently changed the two shift solenoids in my a340e. Everything was fine after I changed them so I drove around then came home and parked. Wake up the next day and it wouldn't go in reverse (worked directly after replacing the solenoids). It also drives while in neutral. I do some investigating and can't even see the level of the tranny fluid on the dip stick so I had to add a full quart of fluid on top of the 1.7 that I already added back in after the job.
    My theory: Something welded together in the Tranny due to low fluid.
    My hope: Its something small I can fix myself.
    Thanks for any input!
  2. Mar 16, 2019 at 3:33 PM
    Mayor
    Mayor New Member
    JAMIESON
    95 automatic by 210k
    Lifted
    Shoot man, I had this happen or similar. Soon after I replaced tranny. It would drive In neutral and no reverse though it was revving up. May be a chance that you're shifted position sensor on side of tranny is jumbled out of position -got loosened up but I think you're trannys done. Only knowledge I have is that my situation sounds similar.
  3. Apr 11, 2019 at 9:10 AM
    cramos8
    cramos8 New Member
    Colton
    Red 4runner 4x4
    Have you tried adjusting you shift linkage? That might help
  4. Jan 13, 2023 at 10:35 AM
    Mando
    Mando New Member
    2000 sr5 auto 2wd
    Whatever happened with this? In having the exact same issue right now with my 2000 2wd and really hoping it's not the whole transmission.
