Drives in Neutral, Parks in Reverse
Discussion in '2nd Gen 4Runners (1990-1995)' started by Mike557, Jan 31, 2019.
  1. Jan 31, 2019 at 10:08 AM
    Mike557
    Mike557 [OP] New Member
    92 4runner
    Hello all I recently changed the two shift solenoids in my a340e. Everything was fine after I changed them so I drove around then came home and parked. Wake up the next day and it wouldn't go in reverse (worked directly after replacing the solenoids). It also drives while in neutral. I do some investigating and can't even see the level of the tranny fluid on the dip stick so I had to add a full quart of fluid on top of the 1.7 that I already added back in after the job.
    My theory: Something welded together in the Tranny due to low fluid.
    My hope: Its something small I can fix myself.
    Thanks for any input!
  2. Jan 31, 2019 at 12:08 PM
    jester243
    Dan
    Spokane, WA
    first thing I though about was the linkage being messed up, but I have no idea really
    TN_FunRunner likes this.
  3. Jan 31, 2019 at 12:40 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    This is what I thought about too
  4. Jan 31, 2019 at 1:48 PM
    Mike557
    92 4runner
    Right but wouldn't that just cause the gears to be off by one? The gears are not off it's just reverse and neutral that are wonky.
    Backslider likes this.
