drivers seat foam replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by FLOORED, Apr 3, 2025 at 9:27 AM.
  1. Apr 3, 2025 at 9:27 AM
    FLOORED
    FLOORED [OP] New Member
    christopher
    im about to tackle the drivers seat foam replacement as the left side is worn down to the point I can feel the frame on my a** cheek. thankfully the seat cover is undamaged. ordered a set of hog rings from Amazon. all should be here today and will be tackling tomorrow. does anyone have experience or tips for the foam swap. I have cloth seats so the leatherette wrinkles won't be an issue
  2. Apr 3, 2025 at 9:45 AM
    I’ve only done that job once. It will be easier if you use zip ties to cinch the edges of the cover together before placing the hog rings. And have a pair of actual hog ring pliers to close the rings. Using regular pliers will be frustrating.
    Plus remember to observe the standard precautions with air bags.
    How about taking some photos of the process and posing a nice how-to?
  3. Apr 3, 2025 at 9:47 AM
    FLOORED
    christopher
    I've seen some use zip ties opposed to the hog rings. bought the hog ring kit off Amazon that includes the pliers so ill see what works easier.
  4. Apr 3, 2025 at 9:51 AM
    The zip ties are easier for sure. When I did the job it was on an antique car and authenticity was a factor, so I replaced the zip ties with hog rings, but if you don’t care, leave the zip ties!
  5. Apr 3, 2025 at 9:59 AM
    FLOORED
    christopher
    my only concern is longevity of the zip ties vs hog rings. I have tons of zip ties. was watching the car care nut on YouTube that shows how to replace the covers and was emphasizing how careful to be with the trim around the bottom the seat so that's one of my biggest concerns to not damage the plastic trim on the bottom
  6. Apr 3, 2025 at 4:06 PM
    FLOORED
    christopher
    And done. I watched the car care nit a couple times and it was extremely helpful especially with the plastic trim at the bottom preventing those pieces from cracking upon removal. I can now throw upholsterer on my resume
    Fortuner and Sin4R like this.
  7. Apr 3, 2025 at 4:12 PM
  8. Apr 3, 2025 at 4:17 PM
    FLOORED
    christopher
    I decided to use the hog rings. They were not bad to use with the Amazon kit I bought. Feels solid now
    Captain Spalding likes this.
  9. Apr 3, 2025 at 8:50 PM
    Impressive! Did you just replace the bottom cushion? And, did the foam come from Toyota?
    I'm going to guess you got so busy trying to tackle the job you didn't have time to take photos along the way, which is what always happens to me...
  10. Apr 3, 2025 at 10:09 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    I've found that buying O.E. Toyota cushions and covers to repair seats is reasonably more expensive than going to an automotive upholsterer. And, at least for cloth seats, it's not the bulk mouse fur upholstery most of them have on hand.
