Driver's Door Lock
Discussion in '2nd Gen 4Runners (1990-1995)' started by LayneSeely, Jul 5, 2019.
  1. Jul 5, 2019 at 3:24 PM
    LayneSeely
    LayneSeely [OP] New Member
    Layne
    92 4Runner
    hey Folks:
    I just bought this truck and totally missed the fact that there was no door lock tab on the drivers door. Oh well, not too worried but I would like to fix it. When I put the key in the door, all the other doors lock\unlock but nothing happens to the drivers door. I haven't opened up the door panel yet (only had it for 2 days) to see what if anything is missing other than the rod. I would have expected it to at least lock but nope it doesn't. Suggestions?
    Thanks in advance.
  2. Jul 21, 2019 at 9:10 AM
    EscapePod
    EscapePod New Member
    Nicole
    95 4runner 3.0 v6
    Hi LayneSeely,
    I just got a 4runner with drivers door lock problem too. It was the first thing I fixed... I took off the door panel (three screws- 1 in small inside door handle, 2 in armrest), make sure window is up, then use a trim tool to pop the snaps. In mine, it had all the parts to operate but there was too much play and it was getting stuck and the lock tab was jammed from someone messing with it. I replaced the e-clip that holds the lock together to tighten it up. The actual locking problem was fixed by bending the lock rod a bit by hand so that it would engage without getting stuck.
    Good luck
    N
