Drive Shaft OEM or Aftermarket
Discussion in '4th Gen 4Runners (2003-2009)' started by YodaRunHer, Dec 9, 2023.
  1. Dec 9, 2023 at 6:34 PM
    YodaRunHer
    YodaRunHer [OP] 05 4Runner V8 4WD
    North Brunswick, NJ
    2005 Toyota 4runner
    None
    I did a thorough inspection of my 05, 4wd, V8 and I noticed at the drive shaft seal (in the middle) flung grease underneath. Question is, should I order an OEM drive shaft, or is there a reliable aftermarket drive shaft I should get?
    Uploading 2 pics
  2. Dec 9, 2023 at 7:01 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Unless there is up/down play in the slip joint there, you shouldn't need to replace the driveshaft. Grease flinging out there isn't unusual and is often caused by over greasing the slip joint. That grease looks pretty fresh too. No play there, I wouldn't worry about it.
    YodaRunHer[OP] likes this.
