Door lock issue
Discussion in '5th Gen 4Runners (2010-2024)' started by 20204runner1988, Mar 17, 2024.
  1. Mar 17, 2024 at 10:21 PM
    20204runner1988
    20204runner1988 [OP] New Member
    2020 sr5 premium - recently ran into the unsurprising door lock actuator failure on the driver door. Replaced the actuator and everything seemed to be working fine. Lock works fine from inside, locks work fine from the key fob, UNLOCK works fine from the door handle sensor, but the lock sensor on the door handle does nothing when pressed. No beep, no lock attempt...nothing. Same for all sides of the vehicle - unlock works, but lock sensor on driver and passenger side show no signs of life (even the button on the back hatch).
    I have noticed that if I have already locked it from the key fob, then press the lock sensor on the handle (either side, or button on hatch) it will beep and "lock" again, but not if it is wasn't already unlocked.
    Any ideas? Something that needs to be reset? Thanks for any help.
