Door ajar wire
Discussion in '5th Gen 4Runners (2010-2024)' started by doorajar23, Oct 21, 2023.
  1. Oct 21, 2023 at 1:52 PM
    doorajar23
    doorajar23 [OP] New Member
    23 4 Runner
    We are installing power running boards on our 2023 4 Runner. How do I determine which green wire is the door ajar wire, when looking at the harness by the driver's door? wiring harness drivers door 4 runner.jpg
  2. Oct 21, 2023 at 7:41 PM
    doorajar23
    23 4 Runner
    There are several green wires. Is there a way to identify which green wire goes to the factory door ajar signal wire? Preferably without having to test each one by piercing the wire insulation.
  3. Oct 21, 2023 at 10:11 PM
  4. Oct 21, 2023 at 10:58 PM
    HuskyMike
    HuskyMike New Member
    Assuming the wire you need goes to the door switch, can you remove the door switch and see if there is a way to pull on the green wire on the switch and find out which one is moving in that cable run?
  5. Oct 22, 2023 at 2:05 PM
    Steve Berman
    Steve Berman New Member
    Did you figure this out? I was thinking you could maybe either 1) pull the squishy sensor out in the door jam(the one that gets pressed when you close the door) and visually see which wire color - or 2) toggle that same sensor (button) while checking for changes in resistance / continuity in each wire. (clamp meter)
    grizzlypath likes this.
  6. Oct 22, 2023 at 2:20 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I'd just cut them all and as you reconnect them, see when the door ajar lights turn out. That's your guy.
    Of course, this is probably why I don't do electrical work.
    grizzlypath and Tank010 like this.
  7. Oct 22, 2023 at 2:29 PM
    Steve Berman
    LOL:bananadance::bananadead:
    bassist[QUOTED] likes this.
  8. Oct 22, 2023 at 4:41 PM
    Oakboro, N.C
    With all power off,could you use a piercing probe and check continuity from the unplugged switch to the wire you suspect as being correct without the available wiring diagram?
  9. Oct 22, 2023 at 4:42 PM
    Are they from China? They will only work one or two years anyway.
