Does your hood scoop allow water in?
Discussion in '5th Gen 4Runners (2010-2024)' started by nodents2017, Jun 24, 2023.
  1. Jun 24, 2023 at 2:18 PM
    nodents2017
    nodents2017 [OP] New Member
    I have a 2022 TRD Off-road and noticed that after it rains or I go through the car wash the fiber liner under the hood is wet. Is it normal for the hood scoop to allow water in and soak the fiber liner or does that mean the gaskets on the hood scoop need to be reapplied?
  2. Jun 24, 2023 at 2:45 PM
    I've noticed this occasionally, but I assumed it was from the underbody flush. I certainly wouldn't expect the scoop to leak, but I can't say for sure.
    djwantke likes this.
  3. Jun 24, 2023 at 4:45 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    I have been in some bad rains and no water intrusion on insulation. I got mine in April 2023.
  4. Jun 25, 2023 at 1:52 PM
    I’m pretty sure mine leaks, because I’ve seen it wet after power washes.
    edit: actually I’m sure it leaks, because you can tell it took in staining from the soap, bases on color and smell right after washing.
    djwantke and Thatbassguy like this.
  5. Jun 25, 2023 at 5:10 PM
    3JOH22A Toyota Gigolo
    Water is coming in through the front grille, accelerated by the radiator fan if your engine is running. Why do you expect anything under the hood to stay dry in the rain or car wash?
    Old Tanker and 2Toys like this.
  6. Jun 25, 2023 at 5:12 PM
    Never noticed but the engine compartment isn’t sealed anyway.
    Toy4X4 likes this.
  7. Jun 25, 2023 at 5:27 PM
    Why have a hood then? Lol. The hood and the weather stripping is in fact designed to keep water off the engine. Lots of things under the hood don’t like being wet. In fact, my engine bay stays dry in heavy rain, although apparently, the scoop doesn’t like to get wet from certain directions. Not a big deal because the water is absorbed by the liner…but it looks kind of ratty now.
    Thanks for sharing your research! I’ll keep this in mind next time I’m powerwashing!
  8. Jun 25, 2023 at 5:35 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I'm sorry, not possible, unless while in said heavy rain your truck is not moving, or only moving slowly. Now, a hot engine would boil off quite a bit of that water, but everything else subject to wheel spray and water forced through the radiator is going to be wet.
    5six likes this.
  9. Jun 25, 2023 at 6:02 PM
    I don’t know…the radiator pretty much absorbs wind, the radiator fan isn’t driven when the radiator has airflow, (and it blows out, not into the engine as far as I know) so net effect is that water isn’t being forced in. While I can see misty water moving around a bit, there isn’t water pouring in during a rainstorm.
    Anyways the water through the hood scoop isn’t pouring in either, but it’s good to know it can allow water to enter if parked on a slope nose down. I don’t wanna find out if mold can grow in that liner.
  10. Jun 26, 2023 at 2:08 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    The air flow go towards the engine through the radiator, and the fan is always pulling air into the engine compartment although to a lesser degree at times, but the fan is always "driven" even when there's airflow through the radiator from forward motion, i.e. the air never blows outward from the engine compartment, if you still don't think this is true do a little research on the subject.
    3JOH22A likes this.
  11. Jun 26, 2023 at 2:26 PM
    Hood is just there for reducing drag. Everything under the hood gets wet. Don't believe me? Aim a pressure washer at the front grille with the engine running.
    I power wash the engine compartment on the way home from every 4-wheeling trip. Alternator, battery, fusebox, etc. all get thoroughly hosed down with the wand in the low setting. Better to be soaked than to have mud and sand in everything.
    The fan is on a clutch which is driven by the water pump pulley. It's always spinning in the same direction pulling air across the radiator and onto the engine whenever the engine is running. Depending on how hot the clutch gets, the fan is either spinning at full engine speed or a subset of engine speed. The clutch is a simple fluid-mechanical device.
    If you're concerned about mold, just rip out the hood liner. It's only sound deadening. Early 5th gens (like mine) don't have a hood liner. The millions of Tacomas built over the past three decades don't have it, either. If you can actually notice the sound difference and don't like it, install some waterproof adhesive insulation like Noico.
  12. Jun 26, 2023 at 5:50 PM
    As a general caution to anyone, take care using the power washer. I power washed the engine bay on my 4runner once. I though I was being careful with it, but a month later I got a misfire on the #6 cylinder. Water got into the spark plug well and eventually messed up the spark plug insulator and started arcing inside the well. I ended up having to replace the plug and the coil.
    There are places on the engine where water can accumulate and sit, the spot on the valve cover by #6 (driver-rear plug) is one of them. I’m sure the valley below the intake plenum is another. This is a good reason to keep the cover and the liner on, to prevent direct drip down on the engine when it’s sitting.
    BantamEddy and rmiked like this.
  13. Jun 29, 2023 at 10:23 AM
    MAXIM
    MAXIM New Member
    Water gets in trough the factory hood scoop. I replaced hood insulation after 9 years of use because it got mold from hood scoop water intrusion. Small amount not a huge deal. I used carpet plastic self adhesive sheet on backside of new insulation which directs small amount of water from under the scoop out instead of trough insulation. More than a year later - insulator looks brand new.
  14. Sep 5, 2023 at 8:26 PM
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    I didn't have the problem with my 2020 OR. My 23 ORP leaks heavily on the driver's side. Hose pressure only. I will have my hood up in the garage for a few hours. It comes through the acoustic panel, but pours out when I lift the hood. A good drip-dry is due.
    Disappointed.
    McSpazatron likes this.
  15. Sep 7, 2023 at 11:12 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Just slap some silicone con carne alone the inside of the hood scoop seal. Have not noticed any leaking from mine.
  16. Sep 7, 2023 at 11:20 AM
    Southern California
    Clear RTV can usually be found at the 99¢ store. Since engines can run just over the 200°F range, plus the sun beating down on it, I would say RTV would be the best choice as it is usually rated up to 500°F
    If I get the heat shield/sound absorber off, I may just do that.
  17. Feb 6, 2024 at 7:54 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Interesting. Thank you!
    After silicone, I bed I can do this
  18. Feb 6, 2024 at 8:06 PM
    And then absolutely everything broke and came up through the floor. :laughing:
    There’s a certain beauty in those pictures…seeing the 4runner living its best life, for one last beautiful glorious second. Haha:mudding:
    djwantke[QUOTED] likes this.
  19. Feb 7, 2024 at 7:23 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Don't let fear or common sense stop you!
    whippersnapper02 likes this.
  20. Feb 7, 2024 at 7:31 AM
    That’s one of those low IQ owners, huh?
    alittleoff and djwantke[QUOTED] like this.
  21. Feb 7, 2024 at 6:59 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Possibly an IQ of 4 (feet).
  22. Mar 6, 2024 at 1:43 PM
    Does this let water in?
  23. Mar 6, 2024 at 2:19 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It looks like he picked a bad place to cross, snorkel notwithstanding.
    Toolguy73 likes this.
  24. Apr 2, 2024 at 8:13 AM
    garoto
    garoto New Member
