Does SR5 4x4 have the same ground clearance as the TRD offroad?
Discussion in '5th Gen 4Runners (2010-2024)' started by 124runner, Dec 15, 2023.
  1. Dec 15, 2023 at 1:20 AM
    124runner
    124runner [OP] New Member
    the only thing i could find online is that “all 4WD 4runners have 9.6 inches of ground clearance”. is that true?? . i always though trd’s have more ground clearance?
  2. Dec 15, 2023 at 2:21 AM
    Yes, the same.
    Borracho Loco and icebear like this.
  3. Dec 15, 2023 at 9:08 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    All the same. The Off-Road model gives you extra options like a locking rear diff but otherwise the basic driveline/undercarriage is identical.
  4. Dec 15, 2023 at 11:05 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Ground clearance is measured from the ground to the bottom of the rear differential/axle. This is the same on all 4runners and only varies due to tire size.
  5. Dec 15, 2023 at 11:20 AM
    Interesting. I thought any lowest point not limited to rear diff.
    I bet they are same for all 4WD models. For 5th gens 2WD are 9.0in clearance vs 4WD are 9.6in clearance.
    Its interesting for comparison 4WD 4th gen 4Runner only have 8.3in and from Lexus world GX460 is just 8.1in.
  6. Dec 15, 2023 at 11:32 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Considering this is a 4runner forum, the lowest part of a 4runner is the bottom of the rear diff.
    It's not an interesting comparison given both the gx460 and 4th gen 4runner have smaller tire diameters stock than the 5th gen. The 2wd ground clearance is probably exactly the same as the 4wd. Toyota published specifications on ground clearance have been wrong in the past. Look at the 2nd gen tundra for example
    JETSPD1477 likes this.
