Does my 2019 4x2 SR5 have a limited slip differential?
Discussion in '5th Gen 4Runners (2010-2024)' started by Toyotafvr, Mar 21, 2021.
  1. Mar 21, 2021 at 11:51 AM
    Toyotafvr
    Toyotafvr [OP] New Member
    Joe
    Hey guys quick question. Have a 2019 4x2 SR5. Was wondering how do you know if it has a limited slip diff? Did a search but came up empty handed.
  2. Mar 21, 2021 at 12:11 PM
    kbp810
    kbp810 rebmem wen
    Should be listed on your build sheet.
    You can look yours up by VIN here: https://www.toyota.com/owners/my-vehicle/vehicle-specification
    One quick note, many have what Toyota calls an ALSD, which isn’t really a limited slip; it’s just clever traction control using the brakes to act as a pseudo limited slip.
  3. Mar 21, 2021 at 12:41 PM
    Toyotafvr
    Joe
    I will look it up. Thanks for info much appreciated!
  4. Mar 21, 2021 at 2:01 PM
    Toyotafvr
    Joe
    So I did look it and no mention of the type of rear diff it has. But did find a lot of interesting info on it. So thank you again for that !
  5. Mar 21, 2021 at 2:03 PM
    Toyotafvr
    Joe
    I still would like to know what rear diff I have because I would like to know what fluid to use and if I need limited slip diff additive when doing a fluid change. Any info and advice is very much appreciated!
    Thank you in advance!!
  6. Mar 22, 2021 at 4:42 AM
    markmb45
    markmb45 New Member
    South Ogden, Utah
    2013 4Runner Trail Edition
    3” OME Lift, JBA UCA’s, 275/70R17 General Grabbers, ARB air compressor
    Put a jack under the rear diff. Raise until wheels off the ground. Rotate one wheel by hand. If both tires rotate the same direction you have a LSD, if they go opposite of each other, then a standard open diff.
  7. Mar 22, 2021 at 4:47 AM
    I don't think any 5th gens have a traditional clutch pack Ltd. Slip. I think it's an "e-ltd slip", meaning it just works off the brakes/traction control. One wheel spins, and it applies brakes to that wheel, thereby sending more torque to the other wheel, assuming it has grip.
    canadian.bacon likes this.
  8. Mar 22, 2021 at 5:05 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    The manual will tell you what type of oil to use.
    Ironguy likes this.
  9. Mar 22, 2021 at 8:40 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    I could be wrong. But I'm gonna go with ... ALL 4Runners have an open rear differential unless you have a TRD (or Venture of course) which has a locking rear differential (which still is probably "open" until you manually lock it up - electrically, I imagine). LSD's aren't really found in vehicles other than sports cars, mostly because of cost, and because sheeple aren't good enough at driving to handle an LSD in the rain.
    Trail Runnah likes this.
  10. Mar 22, 2021 at 9:22 AM
    Toyotafvr
    Joe
    OK sounds good. Thank you All for the info!!! That helps me a lot. Very much appreciated!!
