Does installing after-market products void the warranty?
Discussion in '5th Gen 4Runners (2010-2024)' started by sanjosekimchi, Mar 3, 2024.
  1. Mar 3, 2024 at 6:47 PM
    sanjosekimchi
    sanjosekimchi [OP] New Member
    Hi all,
    I have a 2024 limited and ordered the cat shields from Cali Raised. Does installing them void my warranty? If I install raptor lights do they void the warranty?
    Thanks
  2. Mar 3, 2024 at 6:53 PM
    steelevo
    Utah
    Welcome. It will really depend on the warranty issue.
    Example 1: You have cat shields, with no other mods, and your OEM head unit goes out. Since the cat shields are only a cosmetic item, it would be impossible for the dealer to find that they caused the OEM head unit to go out.
    Example 2: You have just installed raptor lights, with no other mods, and now your car won’t start. The dealer can find probable cause to deny your warranty claim if they suspect that an electrical issue, from the raptor light install, caused the fault.
    LuLu and Jynarik like this.
  3. Mar 3, 2024 at 6:58 PM
    sanjosekimchi
    Thank you. Makes sense... I'll skip the lights until I'm passed the warranty period.
  4. Mar 3, 2024 at 7:40 PM
    Oakboro, N.C
    Welcome to the forum from North Carolina via Modesto.
  5. Mar 3, 2024 at 7:45 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Pretty good example from steel.
    It is dealer dependent though and how far you take it. With enough money, you can’t prove
    X caused Y to fail.
    steelevo likes this.
  6. Mar 3, 2024 at 7:55 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey welcome here OP,
    Good questions.
    Install them both.
    C'mon, warrantee wait period is too long, you could get hit by a bus before then.
    Cat shields are easily reversible so give er.
    Just send it on the Raptor lights they draw next to nil, and install videos are all over YouTube!
    Goodluck
  7. Mar 3, 2024 at 9:29 PM
  8. Mar 3, 2024 at 9:32 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Your engine and tranny are as solid as they come. The rest can break and can be fixed. Enjoy your modified rig.
  9. Mar 4, 2024 at 4:24 AM
    icebear, steelevo and Texrun50 like this.
  10. Mar 4, 2024 at 6:29 AM
    I'd be more concerned that someone might steal my catalytic converters, causing a $2k - $3k repair bill than whether a dealership would even notice or care that you added more protection, using 8 existing bolts. I've read of some dealerships selling a 4R with cat shields added...
    Raptor lights, on the other hand, seem to have the potential to cause electrical issues and I wouldn't bother, but that's just me.
    Texrun50 likes this.
  11. Mar 4, 2024 at 6:41 AM
    kasper8
    kasper8 New Member
    TEXAS
    Black 2023 ORP
    When dealership was forcing me to buy extended warranty, I told them that I will be doing a lot of mods to the car. He stopped.
    Nick4RNR and steelevo like this.
  12. Mar 4, 2024 at 7:47 AM
    steelevo
    Utah
    Steely123[QUOTED] likes this.
  13. Mar 4, 2024 at 7:49 AM
    Nick4RNR
    Nick4RNR New Member
    Welcome.
  14. Mar 4, 2024 at 8:07 AM
    Not unless the mod causes a failure and the dealer will simply refuse to cover the repair. They don't stamp your windshield with VOID.
    Saker likes this.
  15. Mar 4, 2024 at 8:38 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Unfortunately Dealers may choose not to honor a warranty once a related aftermarket part is installed.
    Toyota head office might refuse to pay for that repair.
    For Raptors install, use Tap-a-fuse for a non-essential item like KDSS.
    Towing fuse etc...
    Buy only Toyota/Lexus Warranties.
  16. Mar 4, 2024 at 10:31 AM
    frios
    frios New Member
    2021 4Runner TRD Off Road Premium
    ノーマル
    I work for Audi warranty, and while it's obviously a different brand, I can tell you how we handle warranty repairs.
    Each warranty job has a labor code attached to it. For example; coolant pump has labor code 1955. Thermostat has labor code 1958. A tail light has a labor code of 9431 and a fog light is 9467.
    So you can see that they are grouped according to their type. Engine cooling related as 19 and exterior electrical as 94. When a vehicle that has been modified comes in, say they had an ecu tune. It gets connected to diagnostics. If the tune is detected, the vehicle will get flagged. Once flagged, you cannot remove the flag. However, it doesn't mean you can no longer repair under warranty. Audi has made it simpler for us and they created a chart. So for ecu tuning, Audi has determined which labor groups can be applied and which are not covered. For ecu tuning, they will say most engine related labor groups will not be covered and anything tied to drivetrain. But, if a headlight goes out, it can still be covered by warranty. And any safety related campaigns and recalls can also be performed.
    I'm not sure how Toyota does it, and I hope to talk to their Warranty Administrator one day to find out.
    Manhattan and mcat707 like this.
  17. Mar 18, 2024 at 5:33 AM
    redrunner2024
    redrunner2024 New Member
    I got an extended warranty ( Toyota Care 10Y/100K:I know it is probably not worth the money, but having the peace of mind that if there are any big issues, it should be covered helps relieve any anxiety. ), mainly for the things I will not be making mods on.
    My 4Runner is mainly a daily driver. It is for the truck-like stuff of a suburbanite dad. On occasion, I may want to go camping or play in the mud.
    Any Mod I use will just be to personalize my runner. This is one of the reasons why I got the last of the Gen 5 Models. There is so much stuff out there; my choices are endless. I got the red one because it stands out. I want it to stand out even more, I do not want it to be boring.
    I would like to add raptor lights and other lights inside and outside. That warranty makes me a little reluctant. I am more afraid of the hassle of proving that minor tweaks didn't cause damage.
    I will first replace the 20v port in the front with the Toyota genuine dual USB port. It looks like an easy installation, and I should be able to do it myself. However, the dealer charges $170/hr for labor, and I will not pay that much for such a simple job for fear of voiding a warranty.
    If I were to get a cat shield, I would just have the dealer install the Toyota one. I'm too old to climb under the truck.
    After that, I will look at interior LEDs, hatch, and approach foot lighting upgrades. All of these are just replacing what came standard in the car. I can't imagine any of those things causing issues. I believe those things would be covered under the warranty act mentioned above.
    I guess I am saying all this because I can relate to the OP. I just spent a fortune on a truck that I love, and my goal is to make it last as long as possible. That being said, I also bought the 4runner to customize it, to have the ability to go off-road, and because it is reliable.
    Why have the truck if I am afraid to use it? If Toyota refuses a warranty because of the minor changes they will have a fight on their hands. From what I have seen, they are pretty reasonable. (Dealerships, not so much)
  18. May 20, 2024 at 7:11 AM
    Tino
    Tino New Member
    New York City
    Just accessories
    Hi, did the cali raised cat shields fit your limited without any problems?
  19. May 20, 2024 at 12:22 PM
    Fu3lC3ll
    Fu3lC3ll I.Am.Limited
    Cris
    2024 Limited Wind Chill Pearl
    Sherpa Needle
    It is my understanding that you can't install the cat shields if the XREAS system is still installed. Cali Raised indicates the shields are not compatible with the Limited trim.
  20. May 20, 2024 at 5:34 PM
    Lost in all the trees
    Lost in all the trees New Member
    West Slope, Colorado
    I installed an aftermarket rear window controller (up/down and hatch pop buttons). Recently, had rear wdw motor fail and get replaced by dealer n/c. I have the Toyota 10y warranty! Don’t know if it helped. But, I did tell service rep in advance. Also, I live on the west slope in CO and spend lots of time in Moab. Rep told me they cleaned out a 1/4’+ of moon dust as well. Maybe being honest helped as well!
  21. May 20, 2024 at 6:07 PM
    Flanker271
    Flanker271 New Member
    Gilbert, AZ
    Let me know how the installation goes. I also have a Limited trim but didn't buy this cat shield because the X-REAS hydraulic lines are in the way. Why didn't Cali Raised release a version that works with X-REAS, I have no idea.
  22. May 20, 2024 at 6:13 PM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    Answer to this is complicated. Magnuson–Moss Warranty Act protects against voiding of warranty, but unfortunately in many circumstances it is up to the dealership to interpret it. For anything clear-cut unrelated, such as honoring engine warranty after you lifted the car, you warranty is safe. For other issues, such as tuning engine and then having differential failure, it is up to the dealer. One of the reasons dealership sometimes doesn't like doing warranty jobs is because warranty pays reduced/fixed hours rate. If they have better work and are the issue is not a straight-forward, then they would rather do that.
    For your specific mod, you are likely safe. However, I'd remove shields prior going to the dealership if you ever have catalytic failure work done under warranty.
  23. May 21, 2024 at 8:17 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I have Raptors no Issues.
    However, I would only install easily removed mods.
    Just in case a factory warranty issues occurs.
    Can just uninstall before Dealer visit.
  24. May 21, 2024 at 8:34 AM
    legend1011
    legend1011 New Member
    2024 White 4Runner TRD Offroad Premium (No KDSS)
    I bought the Cali-Raised Cat Shields for our 2024. They are still in the garage waiting for me to get around to it (I'm waiting to time it for our 1st break-in oil change around 1k). I also want to spray some woolwax while I'm under there.
    I am not hesitating to install them. If I'm paranoid about a warranty issue related to anything exhaust, I will remove them before taking it in. Other than that, they will stay on for anything else.
    To me, the risk of cat theft is higher than Toyota voiding a warranty because of their existence.
    I may wait until the initial warranty is expired before doing anything else to car. I am getting the itch to upgrade the stereo only because I had 2 amplifiers (set of Polk components and 1 12) in our older SUV that this replaced.
