Does CEl caused by gas cap reset itself ?
Discussion in '5th Gen 4Runners (2010-2024)' started by switchman2, Dec 20, 2023.
  1. Dec 20, 2023 at 6:53 PM
    switchman2
    switchman2 [OP] New Member
    George
    2023 4Runner
    Added running board
    Hello folks,
    CEL came on today, removed aftermarket locking gas cap and reinstalled original cap. Its the first time seeing CEL after locking gas cap installed 2 months ago but car has been sitting in driveway for 3 1/2 weeks now (away on travel).
    I drive it for approximately 60-70 miles but CEL is still on.
    I take it it won't reset itself ?
    Dealer trip to reset ? (I don't have obd tool)
    I know the stories about aftermarket gas cap, decided to put locking gas cap 'coz we would be away from home for long time. I live in good neighborhood but there's always a chance on bad elements coming around good areas.
    Appreciate your kind responses.
  2. Dec 20, 2023 at 6:59 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    If you don’t have a OBD scanner, disconnect negative battery cable for about 30 minutes and you will be good if the problem is/was the gas cap
  3. Dec 20, 2023 at 7:01 PM
    3JOH22A Toyota Gigolo
  4. Dec 20, 2023 at 7:07 PM
    switchman2
    George
    2023 4Runner
    Added running board
    Great, I'll try the battery disconnect in the am.
    Thanks to all.
  5. Dec 22, 2023 at 6:32 AM
    Bivouac09
    Bivouac09 New Member
    Bivouac
    2012 4Runner.
    Unknown
    When the problem is fixed the light will shut off.
    If you clear the code and the problem still remains the light will light again
  6. Dec 22, 2023 at 6:48 AM
    Did it work? Or, did the light come back on?
  7. Dec 22, 2023 at 7:54 AM
    switchman2
    George
    2023 4Runner
    Added running board
    Its cleared.
    Took it to dealer as it was on my way to my daughters house, former coworkers son took it in right away. He says it usually clears within 5-10 shutoff/start if its just gas cap issue. I said I've driven it for more time than 10 shutdown/starts so reset was all that was needed.
    I wish I had time to prove the battery disconnect but I threw away the locking gas cap and don't want a repeat of this issue.
    All is well now and thanks again to all assistance. That's what makes forum like this shine !!!
    2Toys and Thatbassguy like this.
  8. Dec 22, 2023 at 11:56 AM
    Did the tech do something or did it clear on its own after all?
  9. Dec 22, 2023 at 1:23 PM
    switchman2
    George
    2023 4Runner
    Added running board
    Yes, tech did a reset.
    Got a bonus work done also, windows down after unlock is now activated.
  10. Dec 27, 2023 at 10:13 AM
    MAXIM
    MAXIM New Member
    I had that happen on 4th gen. Bad cap, stopped clicking when tightened. CEL went out as soon as I got new OEM cap on.
