Does a body mount chop damage or make your 4Runner weaker?
Discussion in 'General 4Runner Talk' started by Longralph2, Sep 8, 2023.
  1. Sep 8, 2023 at 10:55 PM
    Longralph2
    Longralph2 [OP] New Member
    2021 $runner TRD Pro Black
  2. Sep 8, 2023 at 11:08 PM
    3JOH22A Toyota Gigolo
    ^Yes, be prepared to die like men in small-overlap frontal crashes. :stirthepot:
  3. Sep 8, 2023 at 11:11 PM
    I think it might impact a little on crash safety stopping the wheel and tire crashing in to the cab or redirecting outward. Not sure, just a thought. I prefer not to do it but those who do it I hope it's well engineered.
    Thatbassguy and Longralph2[OP] like this.
  4. Sep 9, 2023 at 6:06 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    Assuming you weld in a filler plate where material was removed as it seems like most vendor options provide, I’d estimate the effect is minimal. #unprofessionalopinion
    Captain Spalding and Thatbassguy like this.
  5. Sep 9, 2023 at 6:32 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    If you go that route, better make sure you have great medical liability coverage in the event of an accident.
    Longralph2[OP] likes this.
  6. Sep 9, 2023 at 7:24 AM
    The short answer is yes. I highly doubt that any filler plate is going to be as strong as the factory design. It's a risk everyone takes when they decide to run oversized tires. But, a lot of people do, including myself.
    I think the safest option is to stick with a tire that clears the body mount, or do a body mount relocation.
    brownersd likes this.
  7. Sep 9, 2023 at 8:04 AM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    I think a properly welded plate might actually make that mount extension stronger.
  8. Sep 9, 2023 at 9:51 AM
    Overall strength of the material is probably only one factor. I would suppose the angle of the front face of the stock body mount is very much on purpose. In an overlap crash situation, the front tire is probably going to blow or come off the wheel. And the angle of the stock body mount looks like it’s meant to “catch” inside of the wheel rim and contain the wheel in alignment to the footwell. Essentially, it might be designed to make use of the wheel as additional “crush”’structure to absorb energy in a crash.
    Crashes are like cookies though, you don’t know how it’s going to crumble. So even a stock body mount wont help in every situation. if your wheel is turned it’s gonna miss the body mount. If you’re lifted, you’d probably roll over in a small overlap crash. Even in cars with good overlap crash results, it’s a very sucky way to crash. It best to hit stuff head on wherever you have the ability to control things
    It’s good to consider how mods will affect the whole system…that way you can make adjustments to the way you drive.
    K-Paul, bassist and Thatbassguy like this.
  9. Sep 9, 2023 at 10:42 AM
    Henry J
    Sacramento Ca
    Is a body mount relocate better/worse than a chop?
  10. Sep 9, 2023 at 11:17 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    It's fine. Don't even bother thinking about it.
    Same with the relocation. It's fine.
    kolter45 and Captain Spalding like this.
  11. Sep 9, 2023 at 11:20 AM
    Chris In Milwaukee
    Chris
    If the BMC does, indeed, make the front so weak that I do need to conceptually carry a secondary life insurance policy and I’m endangering myself and every human within which I have near proximity, I also expect the cab to pop off like an ejection seat or separating the saucer from the spaceship thus saving humanity.
    IOW don’t overthink it. Unless you like living in fear. Then dig whatever hole you like.
    :nuclear:
    DangitDad and K-Paul like this.
  12. Sep 9, 2023 at 12:22 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    A lift increases roll over chances. Id be more worried about that then a body mount chop.
    K-Paul likes this.
  13. Sep 9, 2023 at 12:28 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    The short and long answer is no. I certainly did my due diligence and watched all the crash videos. It ain't a thang if you do minimal shave type chop n' weld, and don't buck half it off and cap it. I smell 35's in my future
  14. Sep 9, 2023 at 12:31 PM
    They have done crash test videos with body mount chops?
    Do you have a link?
    bassist and kmeeg like this.
  15. Sep 9, 2023 at 12:31 PM
    Besides, I installed one of these just in case
    BigSkyGuy, K-Paul, 2Toys and 7 others like this.
  16. Sep 9, 2023 at 12:33 PM
    No I mean the stock Runner crash videos, and then theoretical engineer analysis videos suggesting a BMC in the mix , and made my decision.
  17. Sep 9, 2023 at 12:38 PM
    Ahh. And those engineers proved that a chopped body mount would handle an impact the same as the unaltered body mount?
  18. Sep 9, 2023 at 12:43 PM
    No like McSpaz says, ur lucky if the accident works out that ur wheel is turned in the right position and the incoming car hits the right spots, they proved don't be such a worrier for the minimal increase for what it's worth
    raimieb likes this.
  19. Sep 9, 2023 at 12:44 PM
    I don't think the question was whether or not one should worry about it. I think the question was whether or not it would reduce the strength of the body mount. :notsure:
    Also, if I was really worried about it, I probably wouldn't have done it.
  20. Sep 9, 2023 at 12:46 PM
    Ur not wrong! Admittedly, a small part of my decision was influenced by installing 1.25" Spidertrax spacers with red locktite which caused rad rubbing :p
    McSpazatron and Thatbassguy like this.
  21. Sep 9, 2023 at 12:47 PM
    Was it the spacers or the loctite that caused the rubbing?
  22. Sep 9, 2023 at 12:48 PM
    The gorgeous black aluminum spacers, and my overconfidence in goodluck
  23. Sep 9, 2023 at 3:55 PM
    ^^^ This.
    Would that be chocolate chip or oatmeal, or…? Crispy or chewy?
    K-Paul and McSpazatron[QUOTED] like this.
  24. Sep 9, 2023 at 5:53 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    OOOOOHHHH SNAP!
  25. Sep 9, 2023 at 5:53 PM
    Lol!
    Thacrow[QUOTED] likes this.
  26. Sep 9, 2023 at 5:59 PM
    bassist
    bassist New Member
    There’s three important questions:
    1) Does it reduce safety/integrity?
    2) Does it result in any exclusions under your auto insurance policy?
    3) Is there the potential for a lawyer to use it against you in a liability situation.
    The first one is a ?
    The second one can be answered by reading one’s insurance policy, which is good practice regardless.
    The third one is obviously a yes, because that’s sort of their job.
  27. Sep 9, 2023 at 6:10 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    No, no, and no. Absolutely not. No. No. Nope. No. Not even a little.
    First one. Nah dude. No. The plate I welded is MUCH thicker than the stock metal which is poor quality mild steel and rusting after a year. If anything it's stronger.
    2nd two. No. Bring the computer models into the court room showing this. It's really impossible to even speak to either. It's all presumption.
    To actually show it in any way. And I don't want to use the word prove because you'd need to make assumptions when modeling a crash, it would take far more resources than available.
    Where it could get used against you is if you clearly did a terrible job and it was falling off especially if it been documented prior to a crash that was clearly at least in part caused by this. And I've seen crashes on YouTube where the body comes off the frame. That's even possible without modifications. But again no. The times and resources to allocate and it really can't be proven. It's just absurd.
    Rob41 likes this.
  28. Sep 9, 2023 at 6:26 PM
    bassist
    bassist New Member
    The answer to number two has nothing to do with computers. It has to do with the actual insurance contract, and whether it would fall under any written exclusions.
    The answer to number three is based upon lawyer and jury quality.
  29. Sep 9, 2023 at 6:44 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    There's a lot of modifications out there. If there were an issue with insurance we would hear about it and everyone would be warning everyone about it.
    The lawyer thing. You'd need to prove it. Which you can't because it wouldn't cause an issue. Any lawyer or person would do that I just did. "OK so your position stands on no data at all. No theoretical modeling, no crash statistics, nothing? OK, welcome to the counter suit."
  30. Sep 10, 2023 at 12:27 AM
    I think this is the 5th gen steel ratings
