Do NOT overtighten your transmission drain bolt! (Carnage included)
Discussion in '3rd Gen 4Runners (1996-2002)' started by amccullough, Jul 4, 2024.
  1. Jul 4, 2024 at 11:47 AM
    amccullough
    amccullough [OP] New Member
    Andrew
    Learn from my idiocy and ONLY use a torque wrench when tightening your transmission drain bolt, or else the pic below can happen. Did this using a hand tool, not a power tool, and THOUGHT I was doing it with a light touch.
    This is from the manual transmission on my 98 4runner. I've tried loading the threads up with red rtv and crush washer, but it still leaks like mad. Now I'm faced with buying a rebuilt transmission for about $2K. An expensive mistake I hope no one else makes.
    java and icebear like this.
  2. Jul 4, 2024 at 12:18 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    That nice chamfer on that opening is begging for an 'O' ring. What kind of seal, if any, was on the drain plug?
  3. Jul 4, 2024 at 12:33 PM
    amccullough
    Andrew
    Oddly it had no seal when removed and never had a leak with 180K+ miles. I wasn't using a seal when I over tightened it, but have tried multiple types since hoping I could plug up the crack enough with no luck. The best result was a flat copper washer and some generous red rtv on the threads and it slowed the leak quite a bit, but still got a few drops overnight.
  4. Jul 4, 2024 at 12:41 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I was thinking that obtaining an 'O' ring from a tractor supply store or similar retailer might give you some relief while you can obtain that replacement transmission.
    Another avenue to explore might be using an oversize helicoil or another type of thread repair. Such as a "twinsert" or something along those lines. Once a repair is chosen then you could take your original drain plug to a machinist with details of the thread dimensions so that an oversize plug could be made. These alternatives should be far less expensive than a transmission replacement and could be accomplished with the transmission still installed. These types of thread repairs are accomplished on aircraft turbine engines, so it is a possibility for you.
    Wvmoonshiner and Evo03 like this.
  5. Jul 4, 2024 at 12:46 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    On the flip side, since it might be difficult to find a replacement transmission, I would not discard the transmission you have since that case could possibly be weld repaired and new threads could be cut after the weld. Transmission would have to be assembled and cleaned thoroughly for the weld to be performed, but a machine shop could accurately cut new threads and as long as the drain plug is not damaged, it could be reused. I have personally seen these types of repairs performed on gearboxes. It just depends on how near and dear the truck is to you.
  6. Jul 4, 2024 at 12:57 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Justthemechanic likes this.
  7. Jul 4, 2024 at 1:03 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    This is an interesting idea and could solve the problem. I have no experience with this epoxy adhesive, but I have used others that have structural strength.
    Edit: Obviously this might be the most cost effective repair assuming that it works. Even if it doesn't, it would not prevent other types of repair.
  8. Jul 4, 2024 at 1:35 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    The solutions discussed above may help in the near term. I wonder how likely that crack is to propagate. Maybe not very likely, but it's something to keep an eye on.
  9. Jul 4, 2024 at 1:41 PM
    Daddykool
    Can that crack be cleaned and welded? I think that your attempts may be failing because the bolt always re-widens the crack whenever you tighten it even a little. So maybe creating a new drain hole would work.
    My thought is this: clean and weld that crack so that it’s positively sealed. Then weld a round plate over the entire opening, and drill/tap a new smaller hole into that plate. It’s a drain after all, so as long as the fluid will come out, you’re ok. You can use whatever bolt/washer system you prefer at that point. Based on what you see in person, might this work?
  10. Jul 4, 2024 at 3:32 PM
    3JOH22A Toyota Gigolo
    Is the drain bolt on the pan? Is the pan not replaceable?
    Sealant shouldn't touch oil while curing. Drain the oil and douse the area with brake cleaner before using sealant. Refill the oil only after sealant has cured. Same story with JB Weld or any other metal epoxy.
    You can even install a Fumoto valve "permanently" with a metal epoxy and just use that to drain in the future.
    Powerstroke, icebear and Daddykool like this.
  11. Jul 4, 2024 at 4:06 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I got so wound up with thinking about how to fix those threads that I didn't even think about it being a pan! :anonymous:
  12. Jul 4, 2024 at 4:36 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    I could be wrong BUT most all manual transmissions I have ever dealt with do not have a pan, the drain plug is in the transmission housing.
    icebear and 3JOH22A[QUOTED] like this.
  13. Jul 4, 2024 at 4:53 PM
    ^Interesting. The ones from the past 20 years (A340, RC62F) had steel pans.
  14. Jul 4, 2024 at 4:58 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Well as I stated "I could be wrong", that being said again, I believe the A340 is an automatic transmission, which would have a pan on the bottom with a drain plug.
    3JOH22A[QUOTED] likes this.
  15. Jul 4, 2024 at 5:07 PM
    I used "teflon tape" on my oil drain plug. Seemed to work great. Now I have a coated washer. Just checked the trans drain bolt. I forgot to use a coated washer and i had a drip on the bolt head. Ofcourse you need a crush or coated washer!
  16. Jul 4, 2024 at 6:45 PM
    Torque spec for auto is 20#'s.
  17. Jul 4, 2024 at 6:45 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Uses a 'crush' washer
    Part even has a factory part number
    Same for the differentials
    SR5 Limited likes this.
  18. Jul 4, 2024 at 7:00 PM
    backpacker
    2023 TRD ORP
  19. Jul 4, 2024 at 7:25 PM
    Here's the automatic drain plug crush IMG_0465.jpg washer.
    backpacker likes this.
  20. Jul 4, 2024 at 7:46 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    backpacker[QUOTED] likes this.
  21. Jul 4, 2024 at 7:57 PM
    I gotta swap out two more quarts.:)
  22. Jul 5, 2024 at 6:14 AM
    Don't want to use steel crush washer on aluminum casing. There's another P/N for aluminum washers like the type used on transfer case plugs. A bit of Googling shows the older manuals had this kind of weird design without a separate pan:
  23. Jul 6, 2024 at 8:08 AM
    Pretty sure those diff crush washers aren't steel. Amazon sellers are idiots.
  24. Jul 7, 2024 at 7:54 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    They're not steel
    That's what happens when you have a 5th Genner trying to inform 3rd Genners about their vehicles :facepalm:
  25. Jul 9, 2024 at 5:58 AM
    Hey now, I have a 3rd gen, just not a 3rd gen 4R :cookiemonster:
  26. Jul 9, 2024 at 7:24 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    That's how some people learn.
    What's the saying? "Good judgement comes from experience, and experience comes from bad judgement."
    java likes this.
  27. Jul 9, 2024 at 7:29 AM
    Schlappesepple
    2020 ORP
    How hot does the transmission get? Would something like solder work? I assume you could clean the threads with a tap pretty easily after that.
    For anything filling the crack, I'd worry about complete penetration, but I can picture silver solder or something working if you can thoroughly heat soak the area.
    If you want to go full hillbilly fix on it, I'd also consider a rubber wrap outside of the bolt with a hose clamp (either diy or store bought Fernco fitting style).
