Do I need rear Sway bar ned links for a 3 inch lift
Discussion in '3rd Gen 4Runners (1996-2002)' started by Drewski007, Feb 5, 2024.
  1. Feb 5, 2024 at 7:13 PM
    Drewski007
    Drewski007 [OP] New Member
    Drew
    1997 4runner
    Lifted 2.5 inches
    HI! I was curious if I need to put on rear sway bar end links for a 3 inch life or if I am ok with just the fronts.
    Thanks Drew
  2. Feb 5, 2024 at 11:48 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    What you need to do is lower it, otherwise your cv axles will tear boots like no one's business
    You'll also need to relocate your panhard bar mount
    Drewski007[OP] likes this.
  3. Feb 6, 2024 at 12:00 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    3 inch lift here with about 16k-18k miles on it. CV boots are fine. A little more worn than when I did the lift. I imagine I'll get at least 30k more out of them.
    I didn't need to do the end links. I have some...been meaning to put them on. Been just fine stock tho.
  4. Feb 6, 2024 at 5:56 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I have a 3" lift here with no diff drop. 5th gens don't require this. 3rd gens might...
    CV boots and sway bars are fine on mine.
    One of the most important things is the panhard bar. DRKDSS makes a bolt on solution to correct the geometry there. If you're asking about a 3rd gen you may have to weld a bracket in from SRQ or Opt Off Road PCK.
    Correcting the sway bar links is ideal but not nearly as important as the panhard bar mounting location.
    Edit: Be careful with aftermarket front links. If they break they will tear a CV boot. I'd recommend a relocation from for the front. Extended links for the rear.
    icebear and Drewski007[OP] like this.
  5. Feb 6, 2024 at 6:37 AM
    Drewski007
    Drew
    1997 4runner
    Lifted 2.5 inches
    Thanks so much for your responses. This page is great. I sincerely appreciate it.
    Regards,
    Drew
  6. Feb 6, 2024 at 12:07 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    The last time that I lifted a 3rd generation 4R in the rear I was definitely glad to have extended links. I would get the links and if you decide that you don't need them just return them.
  7. Feb 6, 2024 at 12:23 PM
    Drewski007
    Drew
    1997 4runner
    Lifted 2.5 inches
    Thanks!!
  8. Feb 13, 2024 at 12:22 AM
    01 4runner
    01 4runner New Member
    01 4runner
    I have a 3" lift on mine they have a spacer kit for sway bars that allow you to use the stock end links they measure about a inch I needed new end links anyway so I run the stock 3rd gen front end end links on the rear and 2nd gen Toyota 4Runner rear end links on the front as for the cv axles I've got 54xxx miles out of mine just now getting ready to change them
  9. Feb 13, 2024 at 12:25 AM
    01 4runner
    01 4runner
    Forgot about the rear panhard bar I bought a hyme joint panhardbar and hyme joint rear trailing arm kit that was designed to correct the issue I daily drive my 4runner
