Discolored Paint/Finish(?) on Steering Wheel Airbag Cover
Discussion in '5th Gen 4Runners (2010-2024)' started by RockDoc18, Mar 8, 2021.
  1. Mar 8, 2021 at 3:34 PM
    RockDoc18
    RockDoc18 [OP] New Member
    Hi all,
    I'm running a 2017 SR5 and have a question regarding the paint/finish(?) of the plastic piece that covers the airbag portion of the steering wheel. In short, I noticed some crusty stuff on the plastic piece and wiped it using the only cleaning wipes in my car, which turned out to contain 75% ethyl alcohol. As a result, some of the paint/finish(?) came off the plastic piece, and it now looks like crap. Any thoughts on how to restore the paint to its original color/finish? After looking online, it seems that Black Graphite (Code FB22) is the original color but I'm not sure. Any help would be greatly appreciated!
    Cheers
  2. Mar 8, 2021 at 6:32 PM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    Have you tried a protectant like aerospace 303, armor all or something similar? That may be enough to bring some color back.
  3. Mar 8, 2021 at 6:51 PM
    mac1usa
    mac1usa New Member
    Have you considered maybe trying some Lexol leather conditioner on it? Maybe try a very small spot first regardless of what you try.
  4. Mar 8, 2021 at 6:58 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    I mean....it's probably more trouble than it's worth to be honest with you. There are vinyl dyes that come in aerosols. You can take your entire steering wheel apart. There are videos on YouTube that show you how. Then you could spray it, let it cure, and then put the steering wheel together. You could attempt to spray some of the paint in a cup or bowl and then use a sponge brush, but that will look like crap as you'll never get it to blend in just right. You can buy a new airbag straight from the parts counter, but then you have to watch the YouTube video how to take the steering wheel apart. At that point....well it's just more trouble than it's worth.
  5. Mar 8, 2021 at 7:38 PM
    dosomeplowin
    '24 ORP
    It's true - this could turn into a prohibitively large project. If the simple treatments don't work, I'd be willing to try dye (I've dyed portions of leather seats with great success).
  6. Mar 8, 2021 at 8:25 PM
    mac1usa
    mac1usa New Member
    Another suggestion is to see if there is an auto or boat upholstery shop near you maybe for classic cars. Lots of boats shops near me. You would be suprised at the things these craftsman can do. It’s worth a shot anyway v
  7. Mar 9, 2021 at 7:28 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Cross you fingers for an airbag recall? Hey, you've got a good shot at it!
    But in all seriousness, I'm sorry to hear about that OP. Annoying for sure.. Good luck!
  8. Mar 9, 2021 at 7:51 AM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Use fabric or interior dye. Matt black. Use only water based dressing. No ARMOR ALL. They will make plastic crack in time. Also there are some interior cleaner which you can buy from local detail supply store. Not from auto parts store.
  9. Mar 9, 2021 at 8:33 AM
    SmurFJ
    SmurFJ New Member
    Bryan
    2021 Lunar Rock Pro
    Try some warm water with a little dish soap in it- maybe what you were wiping off just spread and made it look discolored
  10. Mar 9, 2021 at 11:24 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    A good auto upholstery shop is a good option. You won't believe what they can do.
  11. Mar 10, 2021 at 4:21 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Can it simply be replaced? I'm not sure they come off without effecting the airbag??
  12. Mar 10, 2021 at 5:14 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Also don’t rub sanitizer on your hands and then jump driving. Known issue.
  13. Mar 10, 2021 at 7:21 AM
    SmurFJ
    SmurFJ New Member
    Bryan
    2021 Lunar Rock Pro
    No. It's all attached together. You can't buy the cover separately
  14. Dec 13, 2021 at 9:15 PM
    T4R.ODIN
    T4R.ODIN New Member
    Andrew
    Gray 2018 SR5 Premium
    Following up here, OP. Did you find a solution? I did the same thing.
  15. Dec 13, 2021 at 9:27 PM
    Those wipes just removed oils out of the plastic. I doubt they removed any finish, unless they became black themselves. I have cleaned many an interior and afterwards, there can be discoloration due to old plastic interior pieces losing their oils from a deep cleaning.
    I just use some Mother's or Maguier's vinyl rejuvenator\protectant (not a fan of Armor All). The oils in them will seep back into the plastic and should remove the discoloration. It may take several applications over a month or so until the discoloration stops coming back.
    Hopefully an easy fix.
    It's always possible that the plastic Toyota used reacts badly and you'll either need to paint or replace it to make it perfect.
    7385 likes this.
  16. Dec 13, 2021 at 10:35 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Not true. I replaced my airbag cover a few months ago because the same thing happened to me. Not sure about others but my airbag cover when in the sun had some blue color in it. There’s a company that just sells the plastic airbag cover and their cover is true black and oem as well.
  17. Dec 14, 2021 at 12:48 AM
    This is gonna sound really getto, but how about some black shoe polish?
  18. Dec 14, 2021 at 10:01 AM
    T4R.ODIN
    T4R.ODIN New Member
    Andrew
    From whom did you get the cover? And was it an easy replacement? Thanks!
  19. Dec 14, 2021 at 10:13 PM
    spyder918
    2019 TRD ORP MGM
    I got it from a site called 1mautos.com. Yep it was pretty straightforward. I posted about it here - #16062 https://www.4runners.com/posts/260795
  20. Dec 15, 2021 at 9:30 PM
    T4R.ODIN
    T4R.ODIN New Member
    Andrew
    Thank you! Did 1mautos provide instructions? I see that they’re only offering the part without the Toyota emblem now.
  21. Dec 16, 2021 at 2:05 PM
    spyder918
    2019 TRD ORP MGM
    Nah, they may send you a video of how to unplug an airbag but that's about it. You may be able to salvage your existing emblem. You just have to snip through the melted tabs in the back.
    If you need help just DM me.
  22. Dec 19, 2021 at 4:32 PM
    T4R.ODIN
    T4R.ODIN New Member
    Andrew
    Thank you!
