Dirty Rear Hatch solution
Discussion in '5th Gen 4Runners (2010-2024)' started by ProtoJ, Aug 11, 2021.
  1. Aug 11, 2021 at 5:07 AM
    ProtoJ
    ProtoJ [OP] New Member
    Everytime I go on a dirt road the entire rear hatch collects dirt in every nook and cranny. I blow it off before washing. But…..the one spot where dirt just never stops flowing from in the seal on the glass. Is it safe to just blow that out first with an air compressor? It’s amazing how much dirt comes out of that seal if I don’t. Any other tricks or products out there that keep the dirt out of that seal at least? When it’s all spotless clean I come back 5 minutes later and little streams of mud are running down the door, below the door , everywhere!
    MazMan likes this.
  2. Aug 11, 2021 at 6:52 AM
    That's definitely one of the issues with the 4Runner. The back up lights seem to fill with dust also even though they appear to have a tight seal.
    I rarely roll down the rear window unless the car was just washed. I'm afraid of scratching the glass.
    A&P and Toy4X4 like this.
  3. Aug 11, 2021 at 7:18 AM
    mac1usa
    mac1usa New Member
    I have had mine just two months now not taken off road or even driven rain (work from home) but I noticed dust collects there and on rear hatch just sitting in garage. Time for a hand wash
  4. Aug 11, 2021 at 8:16 AM
    Ive been in some high dust situations amd the amount of dust that collects in the tailgate is crazy. Just pop off the hand grips on the bottom of the tailgate, and stick your hand in there. You’ll be able to grab collected dust with your fingers.
    Ive started to take those handhold cups off and stick a hose with low pressure water to rinse the dust out. Do it carefully and keep the water from spraying everywhere inside the tailgate, because it looks like the speaker cones could get wet. Just gently hose down the inside bottom of the tailgate.
    It takes a while, but eventually you’ll get the water to run clear
  5. Aug 11, 2021 at 8:31 AM
    mac1usa
    mac1usa New Member
    In removing the handgrips and spraying water in tailgate; would that not be an issue with moisture and rusting later on?
    I am just thinking of all types of SUVs and tailgates and how so many rust from inside out?
  6. Aug 11, 2021 at 8:40 AM
    @McSpazatron pointed this out to me awhile back.
    I believe the rust is a result of dust plugging the drain holes over time. The tailgate is designed for water to drain through.
    I started to run water on the hatch window and let it run until the water draining out the bottom is clean.
    Toy4X4 likes this.
  7. Aug 11, 2021 at 8:52 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    Yeah, and it never gets totally clean when going through the carwash either! It is what it is on a 5th gen.
    MazMan and Thatbassguy like this.
  8. Aug 11, 2021 at 10:18 AM
    I always end up with a dirty bumper! :mad:
  9. Aug 11, 2021 at 10:24 AM
    mac1usa
    mac1usa New Member
    Going to wash and wash for first time this weekend. So far just garage dust. Getting fluid filmed in Sept and front windows tinted
    So just spray extra water on rear window to go down through hatch if I understand correctly?
    It’s just dusty now but still only two months old and a few hundred miles.
  10. Aug 11, 2021 at 10:28 AM
    Yes. Just let it run down the window and it will drain out the bottom of the hatch. You'll be able to see it running out onto the bumper and see if it's dirty or not. It might not be too bad in there if you haven't been on any Dusty Rhodes yet
    Toy4X4, LandCruiser and interceptor like this.
  11. Aug 11, 2021 at 10:32 AM
    if you constantly have wet dust and organic crap biulding up in there, that stuff will is what will stay permanently wet, and lead to corrosion.
    in my experience, after removing the dust as i described, the metal inside dries out quickly.
    also keep in mind, even if you dont wash it like i described, it will get wet in there regardless, every time it rains or you wash the car. The question then becomes if you want wet mud in there, or a clean surface that will dry quickly.
    Honestly, Im fighting the urge to figure out take apart the plastic tailgate cover and give it a real good hose down every once in a while, just dont know if its overkill lol
    Toy4X4, 7385 and Thatbassguy like this.
  12. Aug 11, 2021 at 10:42 AM
    @mac1usa . If your truck is new and hasnt been in dusty conditions I wouldnt worry about it too much yet.
    Going forward Making sure those drains are open and actually draining is priority number 1. But I also noticed that having clear water run out of them does not guarantee that all the pockets of dust/mud/muck have been cleared out the entire bottom surface of the tailgate. So it might be worth occassionally getting hands in there to feel around. The metal is kinda sharp, so watch yourself.
  13. Aug 11, 2021 at 10:59 AM
    mac1usa
    mac1usa New Member
    Thanks guys. This is my first Toyota and 4Runner. I came out of a 90s Explorer in mint body shape but I babied it. I know those Explorer tailgates rotted something awful especially here in Midwest.
    I am most likely overkill but this 4R is my new baby and will not see winter and only see rain if I get caught in it. I just got a California car cover for winter. Since I know the frames rust I am getting fluid film and plan to do the hitch and skid plate myself.
    I figure I will stabil the gas for winter, cover it, put a tender on battery and start her up every week for 20 mins.
    If you guys have other suggestions please let me know (even on) I did not intend to hijack this thread
    interceptor and Thatbassguy like this.
  14. Aug 11, 2021 at 2:16 PM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    That's why I just stick to mall crawlin'. Cleaner and safer.
    LandCruiser and Rock-N-Roll like this.
  15. Aug 11, 2021 at 2:34 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Negative pressure in the read end...happened on my 300C SRT8 with a flat rear end. There's nothing to do about it, unfortunately, and for clean freaks like me, Im sadge...
  16. Aug 11, 2021 at 2:47 PM
    interceptor
    interceptor Crash Test Dummy
    '21 ABM Venture
    This was lesson one I learned after cruising the beach. They say sand gets into everything, but oh my. I opened the back window for the ride home.. and when I got there... well let's just say that I'm still finding it everywhere inside. I theorize (after opening the hatch) that sand collected between the hatch base and the body recirculated out, up, and into the open window. Woot!
    And, I still have a nice pile of sand in my driveway after spending extended time focusing the rinse on the back hatch area. Ha!
  17. Aug 11, 2021 at 3:21 PM
    Charlievee
    Charlievee New Member
    One thing i do is spay fluid film in all the doors using the drain holes.
    Toy4X4 likes this.
  18. Aug 11, 2021 at 4:09 PM
    Nothing to be done? My friend you just hit on something...
    First one to come up with an ingenious DYI or sellable system to positively pressurize the tailgate wins.... GO!!!
    There’s gotta be someway to incorporate that hood scoop on OR models....hmmm
  19. Aug 11, 2021 at 4:14 PM
    Charlievee
    What do i win?
  20. Aug 11, 2021 at 6:43 PM
    Dang, I should have spelled out “that doesn’t look like an abomination” in the rules lol.
  21. Aug 12, 2021 at 9:10 AM
    TrailGuy2016
    I have the same wheels on my Trail Premium.......they are TASTY. Nice looking rig. (I love silver cars so I'm biased!)
  22. Aug 12, 2021 at 10:40 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Thanks for this Thread guys. Info on this tailgate is good to know. Double glad Krown Rustproofing did my rear hatch along with the rest of the vehicle.
  23. Aug 12, 2021 at 1:08 PM
    Marcor
    Marcor Someday
    SE PA/SE FL
    2021 ORP
    I’m sorry but I don’t follow. Spraying water on the glass with it up and sealed won’t the weatherstrip prevent water from getting down inside the hatch skin??
  24. Aug 12, 2021 at 2:09 PM
    That's what you would think, but actually a lot of the water ends up flowing down through the door itself. I think Toyota knew that even with the weather stripping rain would still find its way in there so they put the drain holes in the bottom of the hatch. The problem seems to be that dust and everything collect in there and they don't drain out well. So if you just run clean water down the window gently it runs down and rinses the rest of the crap out. Otherwise you can open it and pull out the little grab handle inserts in the bottom and you can feel all the stuff in there. I suppose if you had a small vacuum attachment you could just vacuum it out.
  25. Aug 12, 2021 at 2:40 PM
    Marcor
    Marcor Someday
    SE PA/SE FL
    2021 ORP
    Interesting. I would have never thought that. I pick up a lot of dirt dust and sand constantly. I’ll give it a try this weekend.
    Thx for a tip that may save some headaches down the road!
  26. Aug 12, 2021 at 2:47 PM
    The truth is, I dont think the outside weatherstripping on any of the rest of the doors is “waterproof” either. That goes for any other car by the way. That’s why you’ll see every door has drain holes. Part of general maintainance is keeping those holes open.
  27. Aug 12, 2021 at 2:49 PM
    Gumpus
    Gumpus New Member
    If you just want to keep dirt off your hatch all you have to do is lower the rear window, then all of the dirt goes inside the vehicle. Ask me how I know. :homer:
  28. Aug 12, 2021 at 3:18 PM
    Verified and guaranteed to work! I’m still de-dusting the inside after accidentally leaving the window open 3 inches on a dusty road.
  29. Aug 12, 2021 at 3:41 PM
    :rofl:
    Same reason I know, I reckon!
    Fyi, a California car duster makes quick work of most of the dust. Then you can focus on the nooks and crannies! :eek:
    Compressed air is great for getting dust out of hard to reach places as well.
  30. Aug 12, 2021 at 4:09 PM
    interceptor
    '21 ABM Venture
    Two of the best kept secrets that I adopted quite a number of years ago, especially the California Duster.
