Diode dynamics ss3 with Cali raised switch.
Discussion in 'Lighting' started by Trees91, Mar 3, 2024.
  1. Mar 3, 2024 at 3:18 PM
    Trees91
    Trees91 [OP] New Member
    Forrest
    South Dakota
    2023 MGM SR5p
    I'm sure this has been covered somewhere but I can't find my answer here or on google.
    Im wanting to mount ditch lights using Cali raised mounts, diode dynamics (no backlight) ss3 pro, a diode harness and a Cali raised Toyota style switch.
    My question is...if I use the Cali switch (which has a 4 wire pigtail) can I not wire in the "red 2" wire? I don't want the switch to light up at all.
    The diode harness just has three wires.
    I've wired quite a few things and can usually make things work but to be honest I don't really understand it all that well...
    Here's the switch.
    And the harness
    Thanks guys.
  2. Mar 3, 2024 at 3:40 PM
    Trees91
    Forrest
    South Dakota
    2023 MGM SR5p
    Well I think I found my answer. Looks like they'll illuminate when they're turned on. Which I guess is ok.
    If I want to tap the "red 2" wire into the factory dash light circuit does anyone know if they will dim with the rest of the dash lights?
  3. Mar 3, 2024 at 7:43 PM
    Photon_Chaser 44232 and counting…
    Central Coast
    21 TRD Pro
    Shouldn't harm the switch's backlight as I doubt the dash backlight circuit would be anything other than 12V...but it would be a good idea to measure the voltage with a DMM just to be sure what voltage is present.
    As far as the rest of your wiring, it's simple, don't use the DD switch pigtail ('A'), use the 'B' pigtail to wire up to the Cali switch's Red 1 wire.
  4. Mar 3, 2024 at 8:15 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey good luck to you
    I can help from experience
    Illumination wire is indeed 12v and yes the switch backlight will dim with OE dial control.
    My notes
    1. 2020+ T4R tie into drivers side dash OEM wiper defrost switch illumination wire = white, and variable ground = green
    2 . Tie into the 10A Tail lights fuse (tail) under driver side dash with a piggy back fuse holder. They'll only come on with lights
  5. Mar 3, 2024 at 8:37 PM
    Trees91
    Forrest
    South Dakota
    2023 MGM SR5p
    Thanks guys. I may have changed my mind a little already. I think I'll just go with the diode dynamics kit so it'll come with the ss3 with backlight option. I found a dual function switch that has ditch lights and driving lights labeled on it.
    I found it on a YouTube video....it's from aliexpeess so its probably garbage... anyhow he mentioned not connecting the ground from the switch to anything to make the switch not light up at all. Does that sound ok?
    Here's a screen shot, not sure if you can tell anything from the photo. He's saying he has constant power, drl(backlight) function and the actual ditch light function wired to the switch. Other two wires on the switch are not used. Ones is the ground and one is for tapping into dash lights(I think).
