Differential
Discussion in '5th Gen 4Runners (2010-2024)' started by eprince, Aug 5, 2020.
  1. Aug 5, 2020 at 9:55 PM
    eprince
    eprince [OP] New Member
    Erin
    2017 Toyota 4Runner
    Hi everyone,
    What is the best brand for a differential drop when you lift your 4runner? I’m doing a 3in suspension. I wanna know what’s a good brand or if I have to put?
  2. Aug 5, 2020 at 10:01 PM
    Agent_Outside
    Built 2011 T4R Limited
    Don’t bother.
    7385 likes this.
  3. Aug 5, 2020 at 10:34 PM
    Mtbpsych
    Mtbpsych New Member
    Any works, I initially opted out but after my 3 inch lift my CV angles were pretty ugly, so I had the diff drop installed and now they’re not all crooked! At 3 inches I highly recommend a diff drop if you want your CVs to last a while.
  4. Aug 5, 2020 at 11:32 PM
    eprince
    Erin
    2017 Toyota 4Runner
    @Mtbpsych did it come with a spacer for your skid plate as well? I saw a YouTube video that came with it. What brand are you using for your differential drop kit?
  5. Aug 5, 2020 at 11:57 PM
    Mtbpsych
    Mtbpsych New Member
    You don’t need a spacer for the skid plate, the diff is behind the plate. And I’m not sure what brand it is, it’s whatever the shop had they threw on. All it is is a thick washer essentially.
  6. Aug 6, 2020 at 12:03 AM
    eprince
    Erin
    2017 Toyota 4Runner
    @Mtbpsych Thank you. For your help. I have a different question. Would you prefer a cv axle brace as well?
  7. Aug 6, 2020 at 12:31 AM
    eprince
    Erin
    2017 Toyota 4Runner
    I mean a axle drop bracket.
  8. Aug 6, 2020 at 12:32 AM
    Mtbpsych
    Mtbpsych New Member
    Never heard of a axle drop bracket. All you’ll need for a 3” lift is upper control arms and a diff drop for the front.
  9. Aug 6, 2020 at 1:14 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    Diff drop is pointless at 3"
    Probably UCAs not needed either though 3" is getting close
    Some people like spending that money tho
  10. Aug 6, 2020 at 1:16 AM
    Mtbpsych
    Mtbpsych New Member
    Running a 3” lift upfront with no UCAs? Yikes:bananadead::help:
  11. Aug 6, 2020 at 1:21 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    3" right on the line of needing them... I personally wouldn't install them until you see if you can get decent alignment numbers without them. Actually I'd only go to 2.5" just to be safe but an extra .5" probably won't be the deal breaker... had 3 5th gens now, none have needed UCAs at 2.5"...
  12. Aug 6, 2020 at 9:22 AM
    Mtbpsych
    Mtbpsych New Member
    I don’t think I’ve seen anyone get good alignment numbers on stock UCAs at full 3 inches of lift:notsure: And the stock UCAs also will not last when lifted that high and going off road. Aftermarket UCAs are much sturdier and higher quality. To each his own though, what works, works:cheers:
    wmdtech likes this.
  13. Aug 6, 2020 at 4:36 PM
    eprince
    Erin
    2017 Toyota 4Runner
    @Mtbpsych
    That’s what i figured that I wouldn’t need a diff drop bracket if I’m only going 3in lift. I’ve mostly seen it on 4runners if it’s higher than a 4in.
