Differential Drain Plug-Won't Budge
Discussion in '5th Gen 4Runners (2010-2024)' started by Rocko9999, May 8, 2023.
  1. May 8, 2023 at 8:28 AM
    Rocko9999
    Rocko9999 [OP] New Member
    2011 Limited
    Is it me or is there something inherent with the differential drain plugs that causes them to become extremely hard to remove? I snapped a 10mm allen socket trying to remove the front diff drain plug. Fill plug was easy. I put some PB Blaster on the drain as well-no luck. Who the heck put these on so tight? Any ideas or tips on how to remove these?
  2. May 8, 2023 at 9:05 AM
    Sounds like it was over torqued at some point. It’s easy to do on the front diff.
  3. May 8, 2023 at 9:12 AM
    Make sure the fill opens first. I never had issues on Toyota front diffs.
  4. May 8, 2023 at 9:28 AM
    MAXIM
    MAXIM New Member
    Don't use impact gun. Tap 10mm hex in lightly with a hammer and then apply steady counterclockwise pressure with breaker bar. G.L.
  5. May 8, 2023 at 9:30 AM
    Rocko9999
    2011 Limited
    I did that. Nothing. Snapped the first 10mm, second one is not budging with breaker bar. It's like the shop who did the last service way way over torqued this this.
  6. May 8, 2023 at 9:31 AM
    Rocko9999
    2011 Limited
    Fill loosened without issue. Rear dif was piece of cake. Maybe more heat soaking on front causes the plug to seize?
  7. May 8, 2023 at 9:38 AM
    We actually cut a piece off of an old chisel to get the allen. Then the bolt stripped and I noticed it actually has a “Star “or torx on the bolt and then an Allen on the inner part of the bolt. But ended up sucking it out the fill with a tube.
  8. May 8, 2023 at 9:41 AM
    MAXIM
    MAXIM New Member
    I'd spray over it with PB Blaster or other penetrant oil and sleep on it. It will open up tomorrow. I did my on cold diff and not sure if it makes it easier to remove when case is cold or warm after drive. If all else fails - take torch to the case and heat the hell around drain plug. Heat shock will certainly release the bond or if some genius used Red Treadlocker on plug, then heat is only way to turn it.
    missionman likes this.
  9. May 8, 2023 at 9:42 AM
    2016Pro
    Breaker bar and pb blaster or similar will do it. Make sure it stays soaked
  10. May 8, 2023 at 9:48 AM
    Agent_Outside
    Built 2011 T4R Limited
    It’s very common that the front drain doesn’t want to come out. Replace it with the Lexus one.
    Rocko9999[OP] likes this.
  11. May 8, 2023 at 10:00 AM
    alittleoff likes this.
  12. May 8, 2023 at 11:23 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Another tip that has worked for me (I rebuild a lot of old worn out vehicles):
    1) Thoroughly wire brush (use some elbow!) the whole area around the plug to get the rust and crust off
    2) Heat the plug and immediate vicinity with a propane torch. Don't make it glow, just get it smoking a little (note: you'll be changing the fluid anyway, so don't worry about wrecking it)
    3) Remove torch and touch a dinner candle or birthday candle all around the circumference of the plug where it meets the case. The wax will wick into the threads.
    Then use a stubby socket hex bit (short so less likely to break), tap home with a brass hammer to make sure the bit is fully set in the plug, coerce with ratchet or breaker bar of your choice. Keep pressure with one hand against the back of the ratchet or breaker bar to ensure it doesn't pull out of the plug.
    If this doesn't work, the final step is:
    A) Weld a nut onto the drain plug
    B) Remove with socket and breaker
    Jason
    2Toys, 5six, qcTRDct and 2 others like this.
  13. May 8, 2023 at 11:34 AM
    Rocko9999
    2011 Limited
    Great advice. I had our company mechanic look at it. He snapped his Matco 10mm socket and then got it out with a chisel. It's just incredible these become so darn stuck. Thanks for all the advice. I think the Lexus alternate part is a good idea going forward.
  14. May 8, 2023 at 12:16 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    I usually just hit the front diff drain plug squarely and hard with a 32oz ball peen hammer a couple times without the 10mm hex in there. The "shock" releases its death grip. It will still be very tight. Works 99% of the time. Otherwise, carefully chisel without damaging the differential.
    jasonmcelroy and Rocko9999[OP] like this.
  15. May 8, 2023 at 12:25 PM
    Rocko9999
    2011 Limited
    Thanks. How hard are you hitting the plug?
  16. May 8, 2023 at 12:36 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Well, difficult to say but pretty damn hard. I bring it back behind my ear, kinda like a quarterback's throwing motion if that makes sense. You need to hit as hard as you can and stiil hit the target. If your doing it on the ground you may not have enough room to swing it hard enough, but I cheat and use lifts..:)
    Rocko9999[QUOTED][OP] likes this.
  17. May 8, 2023 at 12:37 PM
    Rocko9999
    2011 Limited
    Got it. Hate to miss and knock off a chunk of the diff.
    CygnusX-4[QUOTED] likes this.
  18. May 8, 2023 at 12:42 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Yeah, don't do that...
    5six and Stoney Ranger like this.
  19. May 8, 2023 at 7:41 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    well I was doing the flame torch plug , if it is locked up ...used the water in the ice of the socket/wrench ,,,.
  20. May 8, 2023 at 7:56 PM
    Interesting. I never heard about that bit with the wax.
  21. May 8, 2023 at 8:50 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Farmer trick. Works well.
  22. May 8, 2023 at 9:28 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Yes, get the Lexus 90341-24016 front diff drain plug with the hex head to replace that Toyota allen head 90341-24014.
  23. May 9, 2023 at 10:43 AM
    Rocko9999
    2011 Limited
    Will the wax wick past the copper crush washer?
  24. May 9, 2023 at 11:39 AM
    Doubtful, if it did then gear oil would be leaking out.
  25. May 9, 2023 at 12:10 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
  26. May 9, 2023 at 12:20 PM
    Rocko9999
    2011 Limited
    Really? I will have to look for one of these.
  27. May 9, 2023 at 12:34 PM
    steelevo
    Utah
    These are amazing for Honda rotor screws.
  28. May 9, 2023 at 12:48 PM
    Its the one and only thing I use on the boat. If the screw doesn't loosen with a screw driver by hand I use the manual impact.
    Will save you a lot of headache with stripped screws. And its cheap.
  29. May 9, 2023 at 2:01 PM
    oh boy, these give me bad memories. Mostly because I must be directionally challenged understanding which way to set it. I’ve ended up hammering it with it set to tighten on more than one occasion. That’s a me problem though lol
  30. May 9, 2023 at 2:31 PM
    The one I have has markings which way. Even if it is set to the wrong way it won't hurt anything. It just won't help either.
