Differences b/w Canadian and American 2020-2024 4Runner TRD Off Road Premium?
Discussion in '5th Gen 4Runners (2010-2024)' started by AR1978, Jan 31, 2025.
  1. Jan 31, 2025 at 4:04 PM
    AR1978
    AR1978 [OP] New Member
    2015 4Runner Trail Premium
    I was just wondering if there is a comprehensive list of differences b/w the 2020-2024 4Runner Off Road Premiums?
    Doing some research here and was shocked to find out that the Canadian 4Runner Off Road Premium had dual climate controls.
    Are there any other major differences? I searched around and one thread mentioned it might have automatic head lights as well? Is there a way to swap out the guage cluster so you have it display mph vs km/h?
    djwantke likes this.
  2. Jan 31, 2025 at 4:28 PM
    I think the Canuck versions also get auto head lights? Some of our resident Canadian's will chime in soon enough to help you out.
    @djwantke
    whippersnapper02 likes this.
  3. Jan 31, 2025 at 4:34 PM
    As far as I know they don't get a premium option but their TRD gets the dual zone and auto lights plus I believe a heated wheel before the US did.
    Toy4X4 likes this.
  4. Jan 31, 2025 at 4:36 PM
    I know the gauge cluster is in KPH and they all run off Maple Syrup, oh, and when you honk the horn it doesn't beep. It goes "Aboot!"
  5. Jan 31, 2025 at 4:48 PM
    500 leafs fans to the kiloliter of maple syrup. :canada:
  6. Jan 31, 2025 at 4:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hah
    Thanks
    Well my 2016 was a Trail Premium, I believe it was one of the last years before *TRD Off Road was widely available in Canada.
    I don’t have either of those features :oops:
  7. Jan 31, 2025 at 5:08 PM
    scanny
    scanny New Member
    Ontario, Canada
    Canadians have just TRD Off-Road, there's no Premium trim in Canada. But I understand that all features is very close to US "Premium" version. So Canadian TRD Off-road has dual climate controls, automatic headlights with no option to turn them off manually. Built-in GPS and front/side cameras is standard too. Heated steering wheel is standard from 2023, previous years don't have it (maybe except for Limited). Speedometer is in km/h and mhp but numbers are small : ) I think setting allow you to chose F and mpg for information display but I'm not sure.
    Here's overview from Canadian dealership - 2024 Toyota 4Runner TRD Off-Road 4WD .
  8. Jan 31, 2025 at 5:38 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    they did get auto headlights. Canadian laws on day time lighting is a lot more strict than the US for obvious reasons with the weather and geographic location and everything.
  9. Jan 31, 2025 at 6:12 PM
    scanny
    scanny New Member
    Ontario, Canada
    Canadian laws only mandate DRL. My 2010 SR5 had DRL (cannot be turned off), but lights were manual. Auto lights is a luxury feature, cheaper cars don't have it.
  10. Jan 31, 2025 at 6:25 PM
    FourBelugas
    23 white ORP
    Like US market ORPs?
  11. Jan 31, 2025 at 8:41 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    As of September 1st 2021, "all new vehicles must have headlights and taillights that turn themselves on at dark and dashboards that stay dark if the headlights are off"
    Off Road's in Canada also all come with KDSS and sunroofs.
  12. Feb 1, 2025 at 3:05 AM
    AR1978
    Can you swap out the speedometer if you bring a Canadian 4Runner to the United States so the outer ring on the speed displays mph instead of km/h.
  13. Feb 1, 2025 at 3:43 AM
    Whaler94
    Whaler94 New Member
    Michigan, United States
    2023 ORP white
    Options that you would expect in a $50,000 plus vehicle. My wife has only driven our 23' ORP once to work when we first bought it. She cannot get over the fact that the ORP does not have remote start, auto headlamps and dual zone climate control like her 2008 Highlander did. That is why her car sits outside in the cold and the ORP is warm and cozy in the garage! I am not sure if the new 4r can be optioned with remote start but that is a great option here in Detroit.
  14. Feb 1, 2025 at 5:55 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Aren't Canadian 4Runners offered in a "Hoser" edition.
    Borracho Loco likes this.
  15. Feb 1, 2025 at 7:19 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Probably would be more hassle than it's worth. If it's a newer 4R with the updated cluster you can have the speed displayed digitally in the center in mph or kph. That's what I do when I drive in the States and I don't even look at the analog speedo.
  16. Feb 1, 2025 at 12:18 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Yes our Canadian versions are well equiped. All TRD Off Roads are pretty much premiums here. My '22 ORP has the dual climate, auto headlights and highbeams, puddle lights. KDSS. Factory remote start, moonroof and all the Toyota Safety Sense P tech. Heated seats but not the steering wheel. No JBL sound system. Given the small size of our market Toyota making more cash on well optioned trucks.
    Toy4X4 likes this.
  17. Feb 2, 2025 at 2:06 AM
    Ctreg
    Ctreg New Member
    The Canadian costs 25% more.
  18. Feb 2, 2025 at 4:54 AM
    kouack
    kouack New Member
    Québec, Canada
    4Runner Limited 2024
    Bone stock
    Well i just built a 4runner 2025 limited 4x4 online for 58880.00$ USD in Canuck $ this is 85600,00$ Cad. The same 4runner built here in Canada is 71200,00$ Cad.
    semprenissart and Toy4X4 like this.
  19. Feb 11, 2025 at 5:12 AM
    AR1978
    Is there a setting on Canadian 4Runner dual climate control to switch from Celsius to Fahrenheit?
  20. Feb 11, 2025 at 6:24 AM
    Wouldn’t matter because it isn’t a direct swap to non dual zone vehicles.
  21. Feb 11, 2025 at 6:41 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I looked at the msrp of a Canadian 2024 limited and according to google MSRP was 60400$ CAD which translates to 42k$ USD. The 2024 limited in the US had a MSRP of 50k USD!
    thats a huge difference. Canada is getting much better prices! Although adjusting for cost of living I don’t know how that would compare. Still, Toyota is definitely taking advantage of US consumers. Even more with the new prices of the 6th gen!
  22. Feb 11, 2025 at 7:27 AM
    scanny
    scanny New Member
    Ontario, Canada
    I didn't try it, but in manual there's an option:
    “Unit of Temperature”*1
    Select to change the unit of temperature.
     “Units of Measurement”
    Select to change the unit of measure
    for distance/fuel consumption.
  23. Feb 11, 2025 at 8:00 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Quick, slap a tariff on us :rolleyes:
  24. Feb 12, 2025 at 1:54 AM
    Matt83
    Matt83 New Member
    Northeast
    Block Heater?
  25. Feb 12, 2025 at 4:52 AM
    kouack
    kouack New Member
    Québec, Canada
    Bone stock
    In the list of optional stuff we can get for our 4R.
  26. Feb 12, 2025 at 5:11 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    I heard when you hit FOB the Vehicle says "EH"
