Diff. Breather @ Gas Cap
Discussion in '5th Gen 4Runners (2010-2024)' started by Scarif_1, Jun 15, 2024.
  1. Jun 15, 2024 at 9:02 AM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    Hey all, planning on doing the scuba mod. rear diff. / locker breather plug at the gas cap. Can someone confirm if removing this panel at the rear driver wheel well below the gas door gives me access to the area just below the gas cap? And if there is a specific trim tool for these fasteners that’ll allow me to pull them out with breaking them. Thanks in advance.
  2. Jun 15, 2024 at 9:26 AM
    Saker New Member
    21 Black T4RORP
    Check out the forum post about “Scuba Mods”, I would avoid trying to remove this panel as I don’t recognize these fasteners as removable without possible damage. Slide under your T4R to establish your preferred route before you start.
    Scarif_1[OP], java and SlvrSlug like this.
  3. Jun 15, 2024 at 10:17 AM
    I'm sure you've heard of the ARB version that extends the breather to the engine bay...I, however, opted for the DIY method locating the breather in the open space behind the DS tail light. Others use the jack storage area. The latter two don't require any removal of wheel well splash panels.
  4. Jun 15, 2024 at 12:28 PM
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    I jammed the breather hose up the gas filler neck as far as it would go and zip tied it. I left a 6" loop in the hose, just above the breather, to allow for suspension droop.
    Scarif_1[OP], 2Toys and java like this.
  5. Jun 15, 2024 at 12:38 PM
    java
    java fauxrunner
    2023 ORP ice cap
    +1.
    Scarif_1[OP] and Saker[QUOTED] like this.
  6. Jun 15, 2024 at 12:40 PM
    java
    java fauxrunner
    2023 ORP ice cap
  7. Jun 15, 2024 at 3:22 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks. I’ll leave the wheel well panel alone. Hopefully removing the rubber liner around the gas cap will allow me to daylight and feed the breather line through. I’ll zip tie as high as possible and undersize the hole through the liner to keep the breather plug snug.
    Saker likes this.
  8. Jun 15, 2024 at 3:32 PM
    rageandlove
    rageandlove New Member
    I removed that panel to run the diff breather up there. I actually didn't fully remove it - I left one place attached because you don't need to take it all out.
    Those clips have some prongs you have to compress then they pull through the hole. Super fiddly. I used some small pliers and drive the 4Runner up on blocks so I could sit up while I fiddled.
    They all went back in fine, but even if you broke one it would be cheap at the Toyota dealer.
    Saker likes this.
  9. Jun 15, 2024 at 6:57 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Do you think trim tools like this would’ve helped? Don’t mind paying a little for some specialized tools if it’ll make the job easier.
  10. Jun 15, 2024 at 7:51 PM
    rageandlove
    To be honest, I’m not sure. It has been 9 months, and what I remember the most was just the challenge of getting my hands in a constricted space. There were only one or two that were hard to get at.
  11. Jun 15, 2024 at 8:10 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    I broke those stupid plastic things as I couldn’t get them out without breaking. But yes that is how you access the gas filler area.
    Scarif_1[OP] likes this.
  12. Jun 15, 2024 at 8:57 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Ok, I’ll leave well enough alone and not mess w/ that panel and just feed the line down with the gas cap liner off. Hopefully there’ll be something to zip tie to at the top.
  13. Jun 15, 2024 at 9:55 PM
    java
    java fauxrunner
    2023 ORP ice cap
    if you can get the first type of clip in this picture for replacements, I woild just drill through them to save myself the trouble. When I installed my Scarab washer bottle relocation. I needed to remove the same clips in the front, with they just poking on the engine side I still had to struggle a bit. just my 2cents. These pliers would've come handy as well
    https://images.thdstatic.com/produc...a/svn/sunex-tools-plier-sets-3706v-64_600.jpg
    rageandlove likes this.
  14. Jun 16, 2024 at 10:21 AM
    Scarif_1
    Oakland
    2020 TRD ORP
    Aware of a good write up on the tail light option?
  15. Jun 16, 2024 at 2:10 PM
    Let me search some. I know there was one I followed...
    Saker likes this.
  16. Jun 16, 2024 at 2:14 PM
    Saker New Member
    21 Black T4RORP
    Hey, I found one! :facepalm:
  17. Jun 16, 2024 at 2:33 PM
    Thanks for that. You did a lot more than I, I just did the differential breather, not the locker also.
    @Scarif_1 - this is my original thread, posted 4 years ago when I undertook this project and was looking for ideas, and went with the one to put it behind the DS tail light:
    https://www.4runners.com/threads/rear-diff-breather-extension.13816/
    Saker[QUOTED] likes this.
  18. Jun 16, 2024 at 6:47 PM
    java
    java fauxrunner
    2023 ORP ice cap
    Oh, I hate that website, screen filled with ads, cant figure out what I'm looking at. Gald we have 4runners.com :) Also that looks like the jack compartment.
  19. Jun 16, 2024 at 7:06 PM
    @Saker did it a bit differently.
    Saker likes this.
  20. Jun 16, 2024 at 7:36 PM
    Saker New Member
    21 Black T4RORP
    Oh, sorry….
    Basically the same except 1 small difference.
    java[QUOTED] likes this.
