Dealership Decal Residue :(
Discussion in '5th Gen 4Runners (2010-2024)' started by M-Bear41, Dec 28, 2024.
  1. Dec 28, 2024 at 6:26 AM
    M-Bear41
    M-Bear41 [OP] New Member
    Mojo
    I've recently noticed this decal residue under certain conditions (rain mainly, and under certain light conditions). I never saw the actual decal on, so Toyota of Tampa Bay had removed it prior to me purchasing it. I've tried goo-gone and some Chemical Guys polish to try to remove it, to no avail. I think the slight residue cooked on in the FL heat.
    Does anyone have any suggestions to remove this? I'm currently in a little bit of colder weather so I had to use my breath to reveal it lol. It's driving me crazy :angrygirl:
    Any helpful tips would be appreciated! :bowdown:
  2. Dec 28, 2024 at 6:45 AM
    M-Bear41
    Mojo
    Thank you, I'll go try that now! I appreciate it!
    EDIT: Okay that didn't work either :( I forgot in my original post that I tried to clay bar it, but that also hadn't worked. No nail polish in the house shockingly haha. Razor blade makes me nervous. :D
  3. Dec 28, 2024 at 6:48 AM
    mac1usa
    mac1usa New Member
    Yeah I second trying some rubbing alcohol but try just a little spot at a time. Try to do it when it’s not sunny there in FL.
    I would not use razor blade since you might chip the rear defroster element lines
    M-Bear41[OP] likes this.
  4. Dec 28, 2024 at 7:11 AM
    Imdav2u
    23 TRD PRO
    Try this, it works on a lot of different things.
  5. Dec 28, 2024 at 7:44 AM
    icebear Recovered Kia Owner
    This has been my ol’ reliable so fingers crossed.
  6. Dec 28, 2024 at 7:48 AM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    I’ve had luck with brake cleaner… since you don’t have to worry about messing up your nails!
  7. Dec 28, 2024 at 7:53 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Rubbing alcohol, 90% .
  8. Dec 28, 2024 at 7:58 AM
    cuse93
    cuse93 Ice Station Zebra
    When rubbing alcohol and a microfiber towel doesn't have enough muscle to get the job done, a little gasoline or kerosene has always done the trick for me.
  9. Dec 28, 2024 at 8:23 AM
    4runningMan
    4runningMan New Member
    New Mexico
    I would try an abrasive polish- like Meguiars Ultimate Polish. Should clean it right up.
  10. Dec 28, 2024 at 8:30 AM
    1st post said that didn't work.
  11. Dec 28, 2024 at 8:42 AM
    BoiseG
    BoiseG New Member
    2024 Off-Road Premium
    That was my original thought when reading the thread title, but OP said they tried that and it didn't work. My only other thought would be to try the Goo Gone with a nylon scotch-brite scouring pad and try scrubbing it off.
  12. Dec 28, 2024 at 8:52 AM
    Charlievee
    Charlievee Not new member.
    Use some polish.
  13. Dec 28, 2024 at 8:59 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    MEK or Naptha
  14. Dec 28, 2024 at 9:18 AM
    obxbird
    obxbird New Member
    2018 Toyota 4Runner SR5 Premium
    Denatured alcohol...guaranteed to do the trick.
  15. Dec 28, 2024 at 9:32 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    3M Adhesive Remover aerosol spray
  16. Dec 28, 2024 at 9:33 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I would think dampening a cloth with Mineral Spirits would work.
  17. Dec 28, 2024 at 9:34 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    When I painted cars back in the late '70's, we would use either 000 or 0000 steel wool to clean any over spray from glass that wasn't covered by masking paper. It worked great for removing adhesives after we removed stickers with a single edge razor blade.
    What the OP is seeing is that the sticker has been successfully removed but the glass needs to be polished with a cream and micro-fiber cloth.
    Rocko9999, M-Bear41[OP] and steelevo like this.
  18. Dec 28, 2024 at 9:34 AM
    Durango Dave
    Durango Dave New Member
    Durango, Colorado
    2023 4Runner Off-Road Premium w/ KDSS
  19. Dec 28, 2024 at 9:46 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    That appears to be on the glass. If that is the case, it's etched in. It's going to take an acid to clean it and it's going to be some trial and error.
    Start with lemon juice on a paper towel, tape it over an area and leave it for a while. Later, wash that area and see if it did any good.
    If it did, repeat on a other area. If it didn't, you'll have to try something stronger. Be warned though. Too strong will "frost" the glass.
    You might consult a professional auto detailer to get some ideas.
    kolter45 likes this.
  20. Dec 28, 2024 at 10:32 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Well I was told years ago by a pro that he always used regular oven cleaner aerosol spray. I have since used it with great success.
    Spray it on, let it set for awhile and residue wipes right off. Who knows....it has ALWAYS worked for me.
    LCJ77 likes this.
  21. Dec 28, 2024 at 12:27 PM
    Charlievee
    Be careful, some of the products being tossed out there don't play well with plastic, rubber, clear coat.
  22. Dec 28, 2024 at 12:35 PM
    steelevo
    Utah
    I second the steel wool. Used it when I used to detail for a car lot, some 30 years ago.
  23. Dec 28, 2024 at 12:36 PM
    Charlievee
  24. Dec 28, 2024 at 1:23 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    @M-Bear41
    @alittleoff is giving you the best advice here. This is the best method because it avoids chemicals accidentally coming into contact with other surfaces like your seals and paint. Use #0000 steel wool with a good glass cleaner like stoners invisible glass and it will pull that junk right off. Heck I would do all the glass on the vehicle and follow it up with a ceramic coat for glass or just good old rain-x.
  25. Dec 28, 2024 at 2:32 PM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    Laquer thinner or naphtha lol might be slight overkill ps don’t light a lighter near a of this at all!
    4runningMan likes this.
  26. Dec 28, 2024 at 3:01 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Brake cleaner works great on glass.
    Don’t use it on interior glass if you have tint
    icebear and 2ndGen22re like this.
  27. Dec 28, 2024 at 3:45 PM
    4runningMan
    New Mexico
    Very good reminder!!
    1SilverRunner and icebear like this.
  28. Dec 28, 2024 at 4:05 PM
    SOSHeloPilot
    SOSHeloPilot New Member
    2024 4Runner SR5
    Owned Many Toyotas - Past
    ...^^^... I have the same thing on a recently purchased 4Runner .... some of the procedures listed above really work.
    Just be SUPER careful with some of those on on trim, rubber and paint.
    I will clean the glass again when it gets a little warmer in GA.
    PS ... Google has some good ideas on "how to clean difficult water spots on the windshield"
    Noodles likes this.
  29. Dec 28, 2024 at 4:15 PM
    Charlievee
    Your familiar with the OP's detailing experience or a random individual that may be seeking the same info in the future? Have first hand knowledge of the problem being solved? People are recommending mineral spirits, better to recommend caution so individuals don't mistakenly do more damage. Hell, I've used everything but the mineral spirits trying to remove water spots from the dealer, with little to no luck.
    2016SR5P and M-Bear41[OP] like this.
  30. Dec 28, 2024 at 4:40 PM
    Oh daaang! Righteous grammar take-down! @Charlievee don’t get back up, you’re out for the count!
    Nobody has recommended the blow torch method yet. Heat up the glass real good, then pour some cold water over it right away to shock it. It probably works.
    :poking:
    :p:D
    :anonymous:
    andrewtheadventurer likes this.
