Dealer installed the wrong oil filter
Discussion in '5th Gen 4Runners (2010-2024)' started by Surgekai, Sep 3, 2021.
  1. Sep 3, 2021 at 10:11 AM
    Surgekai
    Surgekai [OP] New Member
    Joe
    2021 4Runner TRD Off Road Premium(White)
    I decided to perform my own oil change on my 2021 4Runner. The dealer did the previous oil changes… when I removed the filter, I noticed that the incorrect filter was installed by the dealer. I’m pretty upset by this since this is a brand new $43k plus vehicle.
    15613-YZZA1 was labeled on the filter. The actual part number is 04152-YZZA1.
    Has the dealer ever installed the incorrect oil filter in your 4Runner? What did they do to correct the issue?
    Pictures shows the used filter compared to the correct filter, 04152-YZZA5.
    DrewMan, Toy4X4, Moon Landing and 2 others like this.
  2. Sep 3, 2021 at 10:18 AM
    MAXIM
    MAXIM New Member
    Wow, I'd be mad. That is not honest mistake but most likely surplus of Camry filters shop wants to get rid of. Dishonesty is far worse than ignorance!
  3. Sep 3, 2021 at 10:24 AM
    Surgekai
    Joe
    Part Numbers are similar, but damn when you install the filter it’s so obvious that the filter is too short.
    A&P, Roland and 7385 like this.
  4. Sep 3, 2021 at 10:32 AM
    Tuco S.
    Tuco S. New Member
    Which dealer did the previous oil change? I'd say call them up and share this info with them.
    Toy4X4, Trd361, Roland and 1 other person like this.
  5. Sep 3, 2021 at 10:34 AM
    Surgekai
    Joe
    Saint Cloud Toyota. I’m heading there after work today.
    Tuco S., Trekker, Toy4X4 and 3 others like this.
  6. Sep 3, 2021 at 10:45 AM
    Txbobcat
    Txbobcat New Member
    2020 Venture
    Go Get em!
    Tuco S., Trekker and Roland like this.
  7. Sep 3, 2021 at 12:56 PM
    Toyofan87
    Toyofan87 New Member
    Seth
    Blue & Grey Hwy Gburg
    1987 Toyota 4Runner SR5
    One size, don't fit all Mr Dealership..
    Roland and A&P like this.
  8. Sep 3, 2021 at 12:59 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    good luck, they probably will offer you a free oil change for the next time but will you go back?
    Old Tanker, A&P and Toy4X4 like this.
  9. Sep 3, 2021 at 1:05 PM
    Surgekai
    Joe
    That’s what I’m expecting…a free oil change. I’ll do my own oil changes from now on. Nobody takes care of your vehicles better than yourself. I should have known better.
    Diazraf, Tuco S., DrewMan and 4 others like this.
  10. Sep 3, 2021 at 1:06 PM
    And people wonder why so many 4R owners skip the 'free' Toyota care...
    If you plan to do your own oil changes going forward, see if they'll give you some free filters and oil instead.
    java, danielmiao, Old Tanker and 7 others like this.
  11. Sep 3, 2021 at 1:08 PM
    Wow! That's a major fail.
    I would be upset too. Good thing you caught it.
    Here I was whining about stripped skid bolts and you had unfiltered oil recirculating.
    Rentroc, Toy4X4, Roland and 2 others like this.
  12. Sep 3, 2021 at 1:09 PM
    Surgekai
    Joe
    Can you imagine if I brought it back in for an oil change? They’ll just toss the used incorrect filter and act like nothing wrong ever happened.
    Roland, A&P and Toy4X4 like this.
  13. Sep 3, 2021 at 1:12 PM
    True, it's very rare to get people to admit their mistakes and own up today.
    steelevo, Toy4X4 and Roland like this.
  14. Sep 3, 2021 at 1:37 PM
    And the next tech might have matched the wrong filter, since it was the one on your truck...
    Tama1968 and Roland like this.
  15. Sep 3, 2021 at 1:46 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Strangely similar post from 2017.
  16. Sep 3, 2021 at 1:54 PM
    olliechristoper
    olliechristoper New Member
    Chris
    I hate to tell you this Joe but your engine is damaged. It is going to be very difficult to prove how bad. A Blackstone analysis at the very least. Running unfiltered oil in a motor does bad things. The only way to tell is to remove and completely disassemble the engine and mic all the parts. At the very least it knocked off 100,000 miles of life off the engine. There are all kinds of fine worn metal particles that are captured in the filter media. If it's allowed to pass then damage occurs.
    I would demand a new motor and if they refused take them to court. This is totally unacceptable. I would be furious. Make sure you document everything.
    ValK83 likes this.
  17. Sep 3, 2021 at 2:10 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    FYI
    https://www.complaintsdepartment.com/toyota/
    Toy4X4 likes this.
  18. Sep 3, 2021 at 2:21 PM
    Good luck with that.
    Old Tanker, wfxt, Han4Run and 5 others like this.
  19. Sep 3, 2021 at 2:33 PM
    Not ideal but I predict the engine will be fine. Document it with the dealer and just start changing it yourself. I never use the dealer for most service because they just suck. While my Runner was in for a new engine harness due to rodent damage, the dealer changed the oil. The tech broke the filter housing drain tool in the housing and left it there. There was no damage but oil rained on me when I removed the housing drain bolt.
    java, A&P and Toy4X4 like this.
  20. Sep 3, 2021 at 2:36 PM
    kgwags87
    kgwags87 New Member
    Guy
    1987 4Runner
    That’s the problem to begin with they started using that type of filter! We get oil filters that are so close to other filters and it is the techs job to ensure that does not happen ask who the tech was and never have them touch anything else on your vehicle! And go to a different shop!
    There are lots of shops that can do it for less other than the stealerships!
    Good luck
  21. Sep 3, 2021 at 2:43 PM
    olliechristoper
    Chris
    It's not about luck. It's all about the facts. Documentation and measurements. Bore Scope, leak down test, pulling pan/valve covers, bearing measurements, cam measurements etc. A service manual has all the wear specs of individual components. Collecting as much data as possible will lead to a positive outcome to the owner. This is gross negligence on the part of the dealership.
    Toy4X4 likes this.
  22. Sep 3, 2021 at 2:53 PM
    olliechristoper
    Chris
    I have serviced many engines in the generator industry with cartridge filters. I do not need to own a 4Runner to assess what was done. This is not an approved filter for that engine. The upper portion of the holes were exposed to large particles being circulated in the engine. Not good. Damage is done and engine is not going to last as long under the same exact operating conditions as one that has the proper filter installed.
  23. Sep 3, 2021 at 3:38 PM
    olliechristoper
    Chris
    Fair enough. I am of the opinion that the damage is done and not reversible. I could go on with more of my accolades, accomplishments and achievements like yourself but I will leave it alone. I was merely qualifying myself. Not that anyone cares.....
    ecoterragaia likes this.
  24. Sep 3, 2021 at 5:39 PM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    Dang! I'm new enough to the 4Runner world that the dealer performed the first service, so the next one is one me and will be done by me but I had no idea that Toyota doesn't use canned oil filters like most of the rest of the automotive world. If I hadn't read this here I would have a shocker coming up when time for my 2nd service. Why do they use the old style filter cartridge instead of the canned type?
    With regard to the arguments above, it does seem to me that if the cartridge is too short to seal against the top of the container that a fair amount of oil is by-passing the filter process, no?
    Roland, wfxt and olliechristoper like this.
  25. Sep 3, 2021 at 5:47 PM
    Roland
    Roland New Member
    In case you want a bit more peace of mind. My first move would be requesting a compression test, to begin with (This is a fast and inexpensive test, the Dealership should do this free of charge, taken into consideration the mistake they made).
    I believe at factory the 4R has 220 psi. You're 4R 2021 should have a compression over 210 psi per cylinder, with no more than 3 percent variation between the highest and lowest readings between cylinders . At least this reveals the condition of your engine's valves, its valve seats, and piston rings.
  26. Sep 3, 2021 at 7:44 PM
    jetmechG550
    jetmechG550 New Member
    Frank
    2021 Off Road Premium
    Shit, our Rolls turbo-fans go 1000 hours between oil filter maintenance, I wouldn't even bat an eye at that. Furthermore, if they clog, it bypasses the filter anyway
    wfxt, A&P, Toy4X4 and 1 other person like this.
  27. Sep 3, 2021 at 8:21 PM
    Just did my first DIY oil/filter change last weekend and I remember you posting about this.
    Were you able to dig out that broken plastic tab?
    I was concerned that this would happen to me. It fits in there pretty tight.
  28. Sep 3, 2021 at 9:21 PM
    Yeah wasn't bad. I depressed the drain valve and grabbed the plastic with needle nose. I think the guy pulled it forward or back to remove it which broke the plastic tool. I use a metal drain from Motivx to drain the housing.
  29. Sep 3, 2021 at 9:28 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    That's a Tacoma 3.5L oil filter. I know because at one point I had the Tacoma and the 4Runner. The 1Z is Taacoma, 5Z is 4Runner. I mistakenly did this too, realized it a few days later and fixed.
    Drove vehicle for 4 more years, 50k miles. Sold to someone else, at 85k miles, no issues.
    Ideal? No, but not the immediate death sentence others might suggest. To be fair, however, it's not great..
    danielmiao, Roland and A&P like this.
  30. Sep 3, 2021 at 10:49 PM
    Cool thanks,
    I was hoping it had a happy ending. That's why I suggested on my oil change thread that it was probably important to pull it straight out rather than putting a side load on it.
