Cylinder 6 problem
Discussion in '2nd Gen 4Runners (1990-1995)' started by 95_T4R_3VZE, May 9, 2017.
  1. May 9, 2017 at 6:49 PM
    95_T4R_3VZE
    95_T4R_3VZE [OP] New Member
    BEN
    1995 Toyota 4Runner V6
    Had an intermittent misfire in cylinder 6, tried a lot of different fixes nothing worked. I took the head off and this is what I found (picture attached). Two exhaust valves white, one dark. Is this a sign of a burnt valve?20170509_180842.jpg
  2. May 9, 2017 at 8:42 PM
    Toyotayoda
    Toyotayoda New Member
    Atlanta area
    1997 SR5 4x4, 302k and counting
    Tacoma whip, 99 console box, tru trac., steering wheel, PWMS and HVAC control out of a 99.
    could be a sign of low compression. Did you do a compression test before tearing the engine down? burnt valve is really easy to spot, will look like someone literally burned it with a torch. With the cylinder head in that position it's easy to check if the valve is seated, atleast somewhat correctly. If you pour water, or some sort of solvent in that chamber it should not be leaking out the intake or exhaust ports, if it does you need to have the valves seated, maybe replace if leaking.
    Bob likes this.
  3. May 23, 2017 at 5:54 PM
    95_T4R_3VZE
    BEN
    It was a bent exhaust valve. Had both the heads cleaned/resurfaced and that valve rebuilt. Thanks for the help!
    Bob likes this.
  4. Sep 2, 2017 at 1:55 PM
    58jake
    58jake New Member
    1990 White 4Runner SR5
    Currently dead
    If you don't mind me ask, about how much did that run you? I might be in your same situation.
  5. Sep 2, 2017 at 2:01 PM
    95_T4R_3VZE
    BEN
    A small shop around resurfaced, rebuilt the valve, and shimmed for $200.
