Cussing on Christmas Eve: cracked TRD Pro Roof Rack Plastic Bracket
Discussion in '5th Gen 4Runners (2010-2024)' started by Connor MacLeod, Dec 24, 2022.
  1. Dec 24, 2022 at 3:26 PM
    Connor MacLeod
    Connor MacLeod [OP] New Member
    Connor
    2023 TRD Off Road
    So while installing my TRD Pro roof rack today, I over torqued a bolt and cracked the plastic mounting bracket as shown here.
    1) how big of a problem is this?
    2) does anybody know if I can buy a replacement for this?
  2. Dec 24, 2022 at 4:23 PM
    irfan0922
    irfan0922 New Member
  3. Dec 24, 2022 at 4:57 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    JB weld…
  4. Dec 24, 2022 at 5:04 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    JB Weld it and forget about it
  5. Dec 24, 2022 at 5:40 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    Thanks, does it need to be that specific plastic bonder body product, or would regular JB weld be okay?
  6. Dec 24, 2022 at 6:59 PM
    TN_FunRunner
    Jay
    W. TN
    You’ll need the plastic type
    Connor MacLeod[OP] and ValK83 like this.
  7. Dec 25, 2022 at 11:34 AM
    2ndGen22re
    CR
    Carson Valley, NV
    The regular JB works just fine on plastics. My advise is to remove the bracket, use a sharp point knife or scribe and scratch up the inside where the JB is to be applied, apply a pool of JB and let it cure overnight. It will be much stronger than the stock ones.
    https://m.youtube.com/watch?v=XObmZIbHOzY
  8. Dec 26, 2022 at 6:45 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    Good call - I'll try it. Thanks!
  9. Dec 27, 2022 at 12:31 PM
    What I've done on cracked automotive plastics before (interior door panel on a Jeep Wrangler) is add either some fiberglass fabric, or even a piece of sheet metal on the glued side. If you're planning on the JB Weld on the underside of the bracket, and there's room for a small piece of sheet metal, I'd add that or the fiberglass mesh to strengthen the repair.
    Or not.
    Saker likes this.
  10. Dec 27, 2022 at 12:53 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Gorilla glue or jb weld, and call it a day.
    Do you plan on using the rack? I'd love to find a trd rack cheap
  11. Dec 28, 2022 at 6:30 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    Thanks - I will be keeping the rack however. I had actually listed the rack for sale on that other 4Runner forum before I installed it, but then I ended up installing it and really liked the look, so will be keeping it.
  12. Jan 1, 2023 at 1:22 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    Thanks to all for the advice on the repair. I used a whole bunch of regular JB Weld on the back side of the piece where it was cracked, with surface prep including sanding, scratching up with a chisel, cleaning, and alcohol wipe. I also incorporated a couple of pieces of perforated metal sheet into the JB Weld for extra strength. It reinstalled with no issues and looks just fine to me!
    2ndGen22re and Captain Spalding like this.
  13. Jan 1, 2023 at 3:30 PM
    :cheers:
  14. Jan 2, 2023 at 1:24 PM
    2ndGen22re
    CR
    Carson Valley, NV
    Good deal, looks great.
    I absolutely love JB.
