Cross member jack point
Discussion in 'New Member Introductions' started by Michael95, May 14, 2024.
  1. May 14, 2024 at 8:09 AM
    Michael95
    Michael95 [OP] New Member
    I’m a newb with a 2016 SR5. I decided to change my own fluids. I’m uncertain but being led to believe there is a single central point where I can raise the front then place my jacks under the frame. Is this true? Is it the round bump I see on the skid plate? And, is the skid plate reinforced so I don’t have to remove it? (My thought is it doesn’t make sense to squeeze under to remove the plate so that you can then lift the 4R so you don’t have to squeeze under. But what do I know?). Thank you for your insights
  2. May 14, 2024 at 8:58 AM
    adamant365
    adamant365 New Member
    2024 Underground SR5P
    You can jack directly on the round bump in the middle/back of the front skid plate:
    I would use a small block of 2x4 on top of my floor jack "cup" to prevent marring/denting of the area around the skid plate lift point.
    However, you do need to remove the plastic valence and front skid to access the filter housing anyway. I guess you could jack up the front, place your stands, remove the jack and then remove the valence and front skid. But on level ground, there is just enough room to unhook the skid from it's front attachment point. I always removed the front skid before jacking the front up.
    EDIT: Forgot to mention, if I was just doing an oil change, I wouldn't jack the truck up at all. It's a little cramped but doable. I only ever put the front up on stands if I was going to rotate the tires as well.
  3. May 14, 2024 at 10:02 AM
    Michael95
    Thanks. So, I’m replacing the front diff oil. I have jacks but no ramps. I just wanted to get a confirmation that the factory skid plate on the SR5 is reinforced so I can lift it where you indicated on the photo.
  4. May 14, 2024 at 10:28 AM
    adamant365
    Yes it is reinforced for that purpose.
  5. May 14, 2024 at 11:23 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey @Michael95
    Took me bloody forever but I found the photos I have saved on this front jack point.
    I’ve been down the rabbit hole on this answer in the past, and when searching the site I kept finding me talking lol
    I believe this is what the reinforcement location looks like under the skid (red arrow)
    Michael95[OP] and steelevo like this.
  6. May 14, 2024 at 12:58 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome to the forum Mchael
  7. May 14, 2024 at 3:06 PM
    DesertSurfer
    DesertSurfer New Member
    Welcome aboard.
  8. May 14, 2024 at 5:28 PM
