Crank no start
Discussion in '5th Gen 4Runners (2010-2024)' started by 4RHaze53, Jan 7, 2024.
  1. Jan 7, 2024 at 10:08 AM
    4RHaze53
    4RHaze53 [OP] New Member
    Steve
    2013 4Runner limited
    Hello all. New to the forum. I have a 2013 limited which ran perfect for 135,000. Then one morning it cranks but will not start. Fuel pump works. No codes. My mechanic is telling me it needs to go to Toyota.
  2. Jan 7, 2024 at 7:05 PM
    Are you using the same key? If the immobilizer chip in the key is faulty that will cause the same symptoms you described.
    2Toys likes this.
  3. Jan 7, 2024 at 7:21 PM
    4RHaze53
    Steve
    When the immobilizer is active the vehicle will not even crank. Engine turns over. Runs with starting fluid.
  4. Jan 7, 2024 at 7:28 PM
    If it runs with starter fluid, then i would assume it is a fuel problem. A fuel pump comes to mind.
  5. Jan 7, 2024 at 9:22 PM
    I had a Toyota rental once and there was a spare key in glovebox. I tried it and it would crank over the engine but engine would not start.
    Tried the original key that they gave me and it started right up.
  6. Jan 8, 2024 at 1:07 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Are you out of gas? Try adding a gallon. Could be bad sending unit saying you have gas when you are at 1/4-1/2 tank.
    RumHamRunner73 likes this.
  7. Jan 8, 2024 at 1:11 PM
    steelevo
    Utah
    Please clarify "Runs with starting fluid". Does it run for 5 seconds or 5 minutes?
  8. Jan 8, 2024 at 1:12 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Fuel filter?
  9. Jan 8, 2024 at 1:16 PM
    Oakboro, N.C
    Doesnt 5th gen only have the sock in the tank with no external fuel filter?
    2Toys and Ripper238 like this.
  10. Jan 8, 2024 at 1:17 PM
    steelevo
    Utah
    Could be. 5 things that could cause a crank no-start issue.
    1 - Bad immobilizer chip
    2 - Ignition system failure (no spark to spark plugs)
    3 - Fuel system failure (no fuel delivery to injectors)
    4 - Air intake failure (no air getting into cylinders)
    5 - Installing aftermarket lights and using the injector fuse (Lol :rofl:)
    Ripper238[QUOTED] likes this.
  11. Jan 8, 2024 at 1:37 PM
    My money is on the immobilizer.
  12. Jan 8, 2024 at 1:41 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    It can't be the Immobilizer if it were it wouldn't run even with starter fluid.
    Rocko9999 likes this.
  13. Jan 8, 2024 at 3:31 PM
    Immobilizers cut off the fuel injectors.
    2Toys likes this.
  14. Jan 8, 2024 at 3:40 PM
    I’d like to hear how long it runs on starter fluid before placing my bet.
  15. Jan 8, 2024 at 4:42 PM
    Does the Limited have a security dash light? That goes out when key is in the vehicle?
    Slopemaster likes this.
  16. Jan 8, 2024 at 7:40 PM
    Probably as long as you’re willing to stand there and squirt. ;)
  17. Jan 8, 2024 at 9:16 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    OP needs a new mechanic if they do not correlate running with starting fluid and fuel delivery problem. I would like to hear the follow up to confirm the immobilizer theory.
    Tank010 likes this.
  18. Jan 8, 2024 at 10:43 PM
    If that’s the case, my bet is on immobilizer key. But why the key chip would go bad, I don’t know, and it might be a pain to rule it out.
  19. Jan 8, 2024 at 11:04 PM
    We will probably never know. A lot of these threads are anticlimactic.
  20. Jan 9, 2024 at 8:17 AM
    Rocko9999
    2011 Limited
    Sadly true. If you are going to join a forum for help, have the courtesy to post a follow up once it's resolved. Hoping the OP does this. It's massively helpful to the next person with this issue.
