Corrosion protection inside the frame?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R Florida, Apr 7, 2024.
  1. Apr 7, 2024 at 6:48 PM
    4R Florida
    4R Florida [OP] New Member
    Northeast Florida
    2024 4R Off Road
    What is currently the best option to treat the inside of a new frame? It seems like all of the film-based products do not have a wand that will go inside the holes without spraying and wasting half of the material out the top of the can and onto the user. Has anyone done this recently with a proven solution? Thanks.
  2. Apr 7, 2024 at 6:58 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    I'm happy with fluid film or krown being professionally applied for $140 each year. Yhey get inside the frame and inside the rocker panels. Living in the rust belt, professional rustproofing goes a long way.
  3. Apr 7, 2024 at 7:00 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I looked, and in Florida I can't find the option to have it done by someone. It's not a big deal here but I plan to move. I don't mind doing it myself as it's very easy if I can find a wand and spray cans that actually work. We used to have Ziebart here a long time ago, but not anymore.
  4. Apr 7, 2024 at 7:02 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP
    There may not be a single person on earth who has bought wands to spray down into the frame, and not had half the can come out the seams.
    Late last summer, I rinsed the entire frame, and treated a 1/4 of the frame for rust in and off (rear end). I really liked Black Fluid Film inside frame. I bought 3M conical spray wands and they’re were the best yet.
    goodluck
  5. Apr 7, 2024 at 7:02 PM
    Do you know how we (I) can get inside the rocker panels
    Thanks
  6. Apr 7, 2024 at 7:02 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Ok, that gives me a possible starting point.
    djwantke[QUOTED] likes this.
  7. Apr 7, 2024 at 7:04 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
  8. Apr 7, 2024 at 7:05 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    The places that apply it commercially drill small holes, apply the product and then inset a plug. Their wands fog the entire area under pressure.
  9. Apr 7, 2024 at 7:06 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    That's what Ziebart used to do. Smelled really bad inside the car for a few weeks if they did the door panels.
  10. Apr 7, 2024 at 7:07 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Yeah, Ziebart is garbage. I have no smell in my 4Runner.
    Trail Runnah likes this.
  11. Apr 7, 2024 at 7:10 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
  12. Apr 7, 2024 at 7:14 PM
    Yes sir, except I actually only used the wands so far not the wax
    Here is the wand kit for extra $
    3M™ Cavity Wax Plus Applicator Wand Kit
    8", 24" and 34" lengths
    https://www.3mcanada.ca/3M/en_CA/p/d/v000533381/
    https://www.amazon.ca/3M-Cavity-Wax-Plus-08851/dp/B07B4DFTXF
    $50CAD:eek:lol
  13. Apr 7, 2024 at 7:20 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    The one I linked to has the 24" and 34" wands. Two cans of 3M and the wands is only $100. I wonder if two 18 oz. cans is enough for the inside of the frame?
    I'll be taking all 4 door panels off to get to the speakers. Should I do in there?
  14. Apr 7, 2024 at 7:33 PM
    Nice, give it a try
    Yes I believe two cans is just the right amount for in the frame. Especially if your trucks new
  15. Apr 7, 2024 at 7:39 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Ziebart was a scam. I had 2 cars done and they took shortcuts on both.They drilled the holes but never sprayed inside the quarter panels on my '78 IH Scout II. I paid for pressure washing on my '73 B300 Maxi Van and they never did the pressure wash and spayed over top of mud.
  16. Apr 7, 2024 at 7:45 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    100 miles. One rain storm.
  17. Apr 7, 2024 at 8:04 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Can those wands be cleaned and reused in the future?
  18. Apr 8, 2024 at 7:11 AM
    3JOH22A Toyota Gigolo
  19. Apr 8, 2024 at 7:39 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    At least you didn't say specify "body cavities"!
    salvojimmy and seakuv like this.
  20. Apr 8, 2024 at 7:41 AM
    seakuv
    seakuv New Member
    Dave
    Palmer, Alaska
    2024 TRD Offroad Premium
    Falken Wildpeak A/T3W, All interior lights LED, Twiststep for the doggo,
    You could also take a look at what Woolwax has to offer. If you already have an air compressor, or could rent a small "pancake" style compressor for a day, you can achieve good results without the hassle of aerosol cans and their limitations. https://www.woolwaxusa.com/ There will ALWAYS be unending discussion about which product is best, be it Fluid Film, Krown, PB Blaster Surface Shield or Woolwax, but in the end I think it mostly comes down to using a lanolin-based application and either carefully doing it yourself or finding someone to do it professionally that you can trust to not take shortcuts.
    djwantke likes this.
  21. Apr 8, 2024 at 10:06 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    They did choose an awkward name with "cavity" wax. Since I'd like to minimize the explosion out of the top of the can, I decided to give the 3M a try. They usually make a decent product, and their wands are supposed to work with their cans. If they don't work right, they can't argue that I mixed brands of cans and wands. I ordered three cans and the wands. If it works, I'll clean up the wands afterward and save them for future use. I figure a good application inside the frame where it's not exposed directly to the elements ought to last a while but not forever.
    I was curious about the ingredients so I looked up what they are. It seems to be petroleum distillates similar to deodorized kerosene and unpurified paraffin. Mineral spirits for cleanup if needed.
    I'll report back on the experience when complete.
  22. Apr 8, 2024 at 10:19 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    You need to remember fluid film creeps, it will spread. fluid film also has a kit to help get into the frame.
    gomiami and seakuv like this.
  23. Apr 8, 2024 at 10:41 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    The question is, will the product prevent corrosion in a situation like this?
    The world now has one less FJ Cruiser. :(
  24. Apr 8, 2024 at 12:42 PM
    Absolutely, the best option is compressor and can of paint. But I ain't got that and don't plan on investing in it yet. Lots of folks have compressors tho
    Thanks
  25. Apr 8, 2024 at 12:42 PM
    Link?
    Thanks
  26. Apr 8, 2024 at 12:44 PM
    Great to hear
    Can't wait to hear feedback
    So "wax' is a common term for creeping, spray products. I bought a can called "chain wax" (used on dirt bikes and shit), after a forum member highly recommended it for fluid film type touch ups. (But it's smelly stuff gotta wear a mask I think)
  27. Apr 8, 2024 at 12:45 PM
    Not sure, I'm sure we could try.
    Could maybe get a second application out of each
  28. Apr 8, 2024 at 12:58 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    The 3M video says to clean the wands by inverting the can and spraying. I have a small airbrush compressor to blow them out and cleanup is with mineral spirits, so I can wipe the wands clean. Save them for next time.
    The "cavity wax" is a thicker paraffin base compared to the lanolin products from what I read. It's all petroleum products vs. lanolin. They say to apply it three times, but that seems like a lot.
  29. Apr 9, 2024 at 3:19 AM
    Spare Parts
    Southern Maine
    22 LR ORP
  30. Apr 9, 2024 at 9:49 AM
    Don’t let anyone drill holes in your 4runner to spray the rocker panels. There are several body plugs under each one that can be removed to get clear access. If you spray in there, go back a day or two after everything has crept and dripped and make sure the rocker panel drains are open (they look like little slits along the seams). Use a little zip tie end to poke in there and clear out any wax that may have plugged them.
    Noodles, djwantke[QUOTED] and seakuv like this.
