Cornfed
Discussion in '5th Gen 4Runners (2010-2024)' started by DaRunna, Dec 9, 2020.
  1. Dec 9, 2020 at 2:25 PM
    DaRunna
    DaRunna [OP] New Member
    SE Mi
    2021 Venture
    2021 Venture got Cornfed today. Easier than I thought after several Jeep’s I’ve owned. Would rather do new shock/ spring set up but this will get me by until stores have parts in stock. 1” up front only for now. Before and after shot89A4D6FB-BD5B-4369-85F0-894CECCB7366.jpg998B77F6-80DD-4ADB-9CBB-0496E3B747D2.jpg
  2. Dec 9, 2020 at 3:02 PM
    Welcome to the forum from Wisconsin!
    7385 and DaRunna[OP] like this.
  3. Dec 9, 2020 at 3:02 PM
    DaRunna
    SE Mi
    2021 Venture
    Mostly looks. Will be at sand dunes and Outer Banks. But I’m sure stock is fine. Can’t ever leave anything alone!
    kbp810, ruiz4251, 7385 and 2 others like this.
  4. Dec 9, 2020 at 3:05 PM
    This forum is only going to make it worse! ;)
  5. Dec 9, 2020 at 5:25 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Do it to it homie...some stuff works better than others but it all pretty much looks eff-ing awesome
    I dont know what to do next ‍♂️
    DaRunna[OP] likes this.
  6. Dec 9, 2020 at 6:54 PM
    kbp810
    kbp810 rebmem wen
    The potential trouble with spacers is that your increasing suspension height without increasing shock travel. Meaning that you run the risk of over compressing the shock, which can lead to a catastrophic failure. The problem is mostly only relevant to Offroad use, or really, really, rough roads (don’t go jumping any train tracks or speed bumps! Lol). You can also mitigate the issue by increasing bump stop size in the front... but you’d almost be to the point where you’re riding on the bump stops over bumps, and then your ride truly would suffer.
    Aside from that, they shouldn’t really have a significant impact to ride quality or anything; aside from all the typical things that go with any lift.
  7. Dec 9, 2020 at 7:47 PM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    Looks great! I like the subtle change, just a little closer to leveled out. I wouldn't stress about ruining your suspension - a 1/2" spacer (resulting in 1" of lift) is not going to destroy anything unless you intentionally try to.
    DaRunna[OP], A&P and Trail Runnah like this.
  8. Dec 10, 2020 at 2:03 PM
    Don't spacers sit on top of the strut assembly? If that's the case they don't compress the spring. They lower the upper mounting point of the strut.
    HondaKen likes this.
  9. Dec 10, 2020 at 2:16 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    That's not right. First, if that were the case, there would be no lift. Second, all a spacer does is move the spring pack down, which in turn moves the lower control arm down, which - magic - raises the front of the truck. This has been discussed ad nauseum and it's disappointing this myth is still circulating.
    Think real hard about how all this works before replying. There's only one way this device works - it drives the lower control arm lower, which raises the truck. If it compressed the spring, it would either: (1) maintain the same ride height, or (2) lower the truck. If you think it "compresses" the spring, then explain in detail how a shorter spring can raise the truck.
    HondaKen and Thatbassguy like this.
  10. Dec 10, 2020 at 4:38 PM
    08TXRunner
    '20 SR5P
    A&P, it can be hard to visualize this stuff. It's all good my man. Keep in mind that even if the spacer is under the top hat it's the same deal - lift by moving the spring pack lower, which drives the spring lower which then drives the lower control arm lower, which raises the truck. It's the only way it can work. It's not easy to picture this in your head, I know. But there's a lot of BS internet myths out there.
    PAMTB252 and A&P like this.
  11. Dec 11, 2020 at 6:44 AM
    08TXRunner
    '20 SR5P
  12. Dec 11, 2020 at 8:13 AM
    DaRunna
    SE Mi
    2021 Venture
  13. Dec 11, 2020 at 8:19 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Why does this thread remind me of
  14. Dec 11, 2020 at 8:52 AM
    Fanimus
    Fanimus New Member
    Montreal, QC
    2020 Venture Grey
    Tint&Visor, 275KO2, 1"FrontLift,
    nice! i did the exact same! i use my vehicle for light off road and camping trips. common sense tells me not to do anything more than a stock vehicle would do. 1in lift makes the vehicle look just right.
    DaRunna[OP] and A&P like this.
