Coolant leak?
Discussion in '5th Gen 4Runners (2010-2024)' started by thirdyota, Aug 26, 2020.
  1. Aug 26, 2020 at 2:42 PM
    thirdyota
    thirdyota [OP] shouldn't be trusted
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    Was filling the windshield washer fluid reservoir today and noticed this pink residue at the front of the engine.
    View from drivers side front...
    View from passenger side front...
    Anyone had this issue?
    werlyb23 likes this.
  2. Aug 26, 2020 at 3:06 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Water pump.
  3. Aug 26, 2020 at 7:44 PM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    How many miles do you have on that engine and water pump?
  4. Aug 26, 2020 at 8:09 PM
    thirdyota
    Brian
    Cincinnati, OH
    Just under 35,000.
  5. Aug 27, 2020 at 2:51 AM
    fixer5000
    fixer5000 the logical one
    steve
    Massachusetts
    2018 limited in nautical blue with redwood leather
    no plans
    id clean it up and snug the bolts..otherwise warranty may work
  6. Aug 27, 2020 at 5:35 AM
    mcat707
    dont clean it or do anything to it. Bring it in as is for them to take care of it under warranty
  7. Sep 17, 2020 at 5:18 AM
    thirdyota
    Brian
    Cincinnati, OH
    Sitting at Toyota waiting to hear what they say about this.
    2Toys likes this.
  8. Sep 17, 2020 at 5:42 AM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    Gonna need a new engine probably.
    canadian.bacon likes this.
  9. Sep 17, 2020 at 5:46 AM
    thirdyota
    Brian
    Cincinnati, OH
    Lol
  10. Sep 17, 2020 at 5:55 AM
    ThePnsh3r
    2020 TRDOP
    :D
    j/k good luck bud. subscribing for the resolution.
  11. Sep 17, 2020 at 4:25 PM
    mcat707
    I would somehow mark the waterpump and bolts where they will have a hard time seeing it so you can check if they did work on it or not. You don’t want to just drive home after they just washed off your visible evidence and called it a day.
  12. Sep 18, 2020 at 12:39 AM
    thirdyota
    Brian
    Cincinnati, OH
    The technician uploaded a photo of the leak to Toyota TAS and started a claim to get authorization to replace the water pump under warranty.
    They are supposed to call me when they know when the part will arrive to schedule replacement.
    McSpazatron and ThePnsh3r like this.
  13. Sep 18, 2020 at 4:43 AM
    ThePnsh3r
    2020 TRDOP
    I vaguely remember seeing this similar issue on some of the other forums, too. Good on you for finding it. Would recommend to others to keep an eye out for it, too. especially as the warranty nears end and if you plan on keeping the car.
    Do your own oil change, change the fluids - spend some time under the hood - it will help you get to know your car better.
    Tradbow, Opteron and thirdyota[OP] like this.
  14. Sep 21, 2020 at 8:46 AM
    thirdyota
    Brian
    Cincinnati, OH
    Received a follow up call from the dealership today. They stated that since there is only residue and no active visible leak with the engine running, they are not able to replace the water pump under warranty at this time.
    So I guess that means it's the good old "Toyota says this is normal"
    o_O
  15. Sep 21, 2020 at 8:58 AM
    Abanero
    Abanero New Member
    2015 Inferno Orange 4Runner TRD Pro
    Unbelievable. The evidence couldn't be more ...well, evident. If you've argued it to the limit, my next step would be to document the clean up and take pictures when more residue shows. Waiting for it to have a full on leak is careless on their part.
  16. Sep 21, 2020 at 9:21 AM
    ThePnsh3r
    2020 TRDOP
    I would wipe it up good and check torque on all the bolts on the water pump. And then keep an eye on it. You can also try another dealership.
  17. Sep 21, 2020 at 9:45 AM
    thirdyota
    Brian
    Cincinnati, OH
    Lol...they said I could get a 2nd opinion if I wanted to and mentioned 3 other local dealerships.
  18. Sep 21, 2020 at 9:50 AM
    Abanero
    Abanero New Member
    I'd exhaust all three if you keep hitting a barrier. I would download the Toyota Owners app as well, that way you can see the notes that are being entered.
  19. Sep 21, 2020 at 10:43 AM
    mcat707
    They didn’t even at least check the bolts and torque them to spec?
    That’s some garbage customer service
    right there. Its shit like this dealerships lose customers and potential customers that could have been recommended to come their way do business with them. Would have taken one of their techs just a few minutes to check.
    peter2772000 likes this.
  20. Oct 1, 2020 at 11:31 AM
    thirdyota
    Brian
    Cincinnati, OH
    A bit of follow up... I called Toyota corporate and started a case to try to get Toyota to take care of this issue. Final verdict... Toyota says this is normal. However, they are unable to say what rate of leakage is not normal.
    I asked them to provide me with a service interval for monitoring coolant leakage and I was told there isn't one.
  21. Nov 21, 2021 at 9:46 AM
    kwright8754
    kwright8754 New Member
    2018 trd ORP w/KDSS
    Any follow up? Mine is leaking pretty good @ 49k miles.
  22. Nov 21, 2021 at 3:17 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Good to know and look out for thanks for this. As an auto mechanic this doesn't look like a water pump failure per say. Usually if it was the water pump it would leak out of the weep hole under the pump or the fan would be wobbly. Gasket failure or loose bolts as already mentioned is the likely cause. But Toyota has no right to say this is acceptable leakage. It should never leak here as shown by the pics.
  23. Nov 21, 2021 at 4:17 PM
    Looks like a gasket failure. Retorquing the bolts isn’t gonna fix that.
    Redwood likes this.
  24. Feb 1, 2022 at 10:29 AM
    kwright8754
    2018 trd ORP w/KDSS
    Bit the bullet and took mine to the dealership today. They’re covering the repair but only because I knew what I was talking about.
    Initially tried to say I was out of warranty and that if something damaged it physically, it wouldn’t be covered anyway.
    These guys are con artists.
    They about lost it when I said I’d need a loaner to leave it there until tmrw. Not impressed with Toyota. Not the product or the reps.
  25. Feb 1, 2022 at 11:55 AM
    Will
    Will New Member
    2022 4 Runner TRD Sport
    Personally I wouldn’t touch it. I am almost positive the water pump is included on the drivetrain warranty. And if you’re dealing with one of those dealerships that have a lifetime drivetrain warranty they are eventually going to be on the hook.
  26. Feb 1, 2022 at 11:57 AM
    kwright8754
    2018 trd ORP w/KDSS
    Can’t really say I like too much about my 4Runner lol. Other than it’s cool looking. Things are breaking, gas mileage is terrible, technology is outdated, and they’re overpriced.
    canadian.bacon and Will like this.
  27. Feb 1, 2022 at 11:59 AM
    Will
    Will New Member
    Careful. There’s others roaming around these forums that will tell you you didn’t deserve to buy one if you can’t keep up with the surprise repairs on almost new 4 Runners. The Toyota quality just doesn’t seem to be there as like I remember it being when I was a kid and my parents owned the product.
  28. Feb 1, 2022 at 12:06 PM
    kwright8754
    2018 trd ORP w/KDSS
    I guess it’s better than my 3 year old sierra that need fuel injectors. GM conveniently didn’t cover injectors under warranty. Figured I’ll get a Toyota and won’t have to worry too much
  29. Feb 1, 2022 at 12:08 PM
    Will
    Will New Member
    Crazy.
  30. Feb 1, 2022 at 3:38 PM
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    While under warranty, the dealer and Toyota will say every leak and drip is normal.
    However when they find a leak after the warranty is over, they will make it sound like if you don't pay them thousands of dollars to fix it right away you engine will blow up into a huge fireball.
    ecoterragaia and Redwood like this.
