Constant power everywhere
Discussion in 'General 4Runner Talk' started by fullerwellness, Nov 11, 2023.
  1. Nov 11, 2023 at 9:43 AM
    fullerwellness
    fullerwellness [OP] New Member
    2008 4runner sport v8
    3"rough country lift 33"s
    So about a month ago I came out ant the rear wiper was on. It would not shut off. I disconnected the battery and that worked. Halloween am the daytime running lights were on in the morning when I opened the garage. Started truck, shut off still on. Disconnected battery they went out. Once I started the truck and shut it off they stayed on. Pulled fuse they go out. Key fobs dont work. When the key is out I can turn on directionals, fan, door windows, open sunroof.... I chanaged the ignition switch, not it. Any help is greatly appreciated
  2. Nov 11, 2023 at 10:14 AM
    Daddykool
    Rodents chewed wires?
    2ndGen22re and Thatbassguy like this.
  3. Nov 11, 2023 at 10:26 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    These kinds of oddball symptoms often indicate a low battery.
    Daddykool and Thatbassguy like this.
  4. Nov 11, 2023 at 10:37 AM
    Oakboro, N.C
    Second on having that battery checked/tested.
    Dang rats can cause lots of havoc as Daddykool mentioned.
  5. Nov 11, 2023 at 10:51 AM
    welcome, check the battery and wires for rodent damage.
  6. Nov 12, 2023 at 3:21 PM
    Do you have any aftermarket lights or other accessories that tap into any factory circuits (either directly, or to power a relay)?
  7. Nov 13, 2023 at 5:42 AM
    fullerwellness
    Chargedthe battery ists a year and a hlf old after sitting for a week it 12.9 if I hook it up I can watch it drop 12.9 12.89 about every three seconds. No signs of rodents have a cat...
