Console safe removal
Discussion in '5th Gen 4Runners (2010-2024)' started by WKeithM, Oct 11, 2024.
  1. Oct 11, 2024 at 12:00 PM
    WKeithM
    WKeithM [OP] New Member
    2024 White TRD Off Road
    None
    I just bought a2024 TRD Off Road and already decided that the console safe is a no go for me. After removing the two bolts the safe will not budge from the console. The console is loose, but the safe will not budge. Has anyone else had this issue?
  2. Oct 11, 2024 at 12:13 PM
    Remove carpet from the bottom of the safe, remove two bolts. Slide safe out.
    You removed the bolts under the carpet, right? If so, apply a little pressure when pulling it out.
  3. Oct 11, 2024 at 12:17 PM
    WKeithM
    None
    After removing the bolts the console was loose, but the safe would not budge.
  4. Oct 11, 2024 at 12:25 PM
    Hold console down and put some muscle into it.
    Bagman likes this.
  5. Oct 11, 2024 at 1:44 PM
    HuskyMike
    HuskyMike New Member
    Is it stuck under a lip somewhere on the console? If you haven't already, try moving it forward and back or side to side before pulling up.
  6. Oct 12, 2024 at 7:28 PM
    WKeithM
    None
    Finally!!!
    It took a lot more than I had by myself. My wife held the console down and I cautiously pulled. No damage to console lid or precious wife. Thank y’all.
