Considering KDSS or not?
Discussion in 'General 4Runner Talk' started by Mel77, Jun 27, 2023.
  1. Jun 27, 2023 at 1:23 PM
    Mel77
    Mel77 [OP] New Member
    Hope this helps someone, because it was a lot of work getting here: A year ago, I bought a 2020 4Runner SR5 Premium for my kid with 20K miles on it. Fell deeply in love with this truck's performance on CO mountain roads in winter. So, bought myself a 2021 SR5 Premium with 15K miles. Put 17" Michelin Defenders on both trucks.
    Second SR5 was a horrible driving POS. How is it even possible to have so much body roll AND incredibly over-sensitive road bump feel at the same time? This truck is an uncomfortable wallowing boat.
    I started trying to find out why these two identical trucks are completely different. 4 months of rabbit hole later, come to find that my kid's truck is not really an SR5. The truck was ordered from the factory by a dealership service manager and is a mashup of several trims: has SR5 hood and 4WD dial, wood trim and cream-colored leather seats, and TRD Off Road Premium suspension with KDSS.
    Part of my rabbit hole involved going to dealerships and driving different 4Runner trims new and used. The SR5 and most of the other trims were very similar handling. TRD Pro was slightly better in road feel but still ridiculous body roll. When I finally found a TRD Off Road Premium with KDSS, the mystery was solved and I bought it. KDSS drives like a different vehicle entirely. Flat in corners, WAY less bumpy ride on the road.
    If you are not going to do off-roading suspension mods, I would say KDSS is absolutely the way to go. The stock 4Runners without it are a varying degrees of misery to drive on road. The TRD Pro I drove had Fox Shocks and it helped some but truly not at all like KDSS did.
    djwantke, 2ndGen22re and Curt56 like this.
  2. Jun 27, 2023 at 3:10 PM
    Umm can't order KDSS with SR5.
    LadeDruck and Thatbassguy like this.
  3. Jul 1, 2023 at 11:24 PM
    Tell us about the dial. Does it have H2, H4, and L4? Or H4F, H4L, and L4L? If it’s the latter, what I think you’ve got there is a Limited that’s has had the wheels and bodywork swapped out, and what you're thinking is KDSS is really the XREAS suspension that comes on the Limited.
  4. Jul 2, 2023 at 4:50 AM
    As mentioned by @Dillusion , KDSS is not available on the SR5.
    Edit: I missed the "not" before.
    In that case, I agree.
    KDSS is a great setup for anyone who wants the best combination of on road handling and off-road articulation. But, for heavily modified vehicles it ends up being a limitation. If I was only concerned with off-road performance, I'd get the standard sway bars and remove the front.
    Old Tanker and 2ndGen22re like this.
  5. Jul 3, 2023 at 4:57 PM
    One and done?
  6. Jul 3, 2023 at 7:31 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just another thing to break. Only helps eith rollover on road.
  7. Jul 3, 2023 at 7:34 PM
    ...and increased articulation for off-roading...
    ...For those who want to keep their sway bars.
    Old Tanker and Captain Spalding like this.
  8. Jul 3, 2023 at 7:56 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    No dude that's just toyota marketing. Doesn't do shit.
    4runners without kdss articulate all the way to their bump stops just like everyone else.
    Just read OPs post. Less body roll on road. Helps with roll over. Less lawsuits.
  9. Jul 3, 2023 at 8:17 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Save up buy Dr. KDSS kit with dash switch and stay deactivated over 12mph* Then it's closer to experiencing best of both worlds.
    Might be all Toyota marketing, maybe ur right, maybe not. We can be chill tho
    KDSS with stock suspension has been studied at length, articulation has acted more like a sway bar disconnect than non-KDSS with stock suspension. Notice the Lexus (KDSS) stays much more level with further travel front travel
    donnermel and Thatbassguy like this.
  10. Jul 3, 2023 at 8:19 PM
    @Mel77 if that's all true and you know you're looking at KDSS - it sounds like quite the unique shitmix, maybe in a good way
  11. Jul 3, 2023 at 8:29 PM
    Lol!
    It's been tested, and it's been proven to provide more overall articulation.
    I thought we had already had this discussion. The idea that Toyota would offer a necessary safety feature as an option on only some trims is ridiculous.
    https://youtu.be/Ueshf401B0k
    Please watch this before you continue to comment in these threads.
  12. Jul 3, 2023 at 8:31 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    We discussed it and we both have the same opinion (as we did prior to discussing).
  13. Jul 3, 2023 at 8:34 PM
    Iunno, in a number of situations, opposing wheels come off the ground before you hit bump. There's legit videos showing KDSS increasing articulation keeping the wheels down longer and traveling further towards bump stops
    Captain Spalding and Thatbassguy like this.
  14. Jul 3, 2023 at 8:34 PM
    Watch the video in my post.
    I am not stating opinions. I am stating facts.
    5six and Captain Spalding like this.
  15. Jul 3, 2023 at 8:36 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    If KDSS was good then the new tacoma would not have opted for an electronic sway bar disconnect.
  16. Jul 3, 2023 at 8:39 PM
    Right no the new Tacoma and the new Runner will have new sway bar tech, KDSS is quite old my friend
  17. Jul 3, 2023 at 8:40 PM
    Why does the new GX (which is probably going to be almost identical to the Prado) opt for KDSS then? Surely you don't think the new Tacoma is going to be the top of the line off-road option?
  18. Jul 3, 2023 at 8:43 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    The sway bar tech they have is as old as sway bars.
  19. Jul 3, 2023 at 8:46 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Toyota talks about the 4th gen tacoma like it is indeed the best off road vehicle ever.
    But let's see what they say about the next 4runner a year from now. Better yet let's see if it has KDSS.
  20. Jul 3, 2023 at 8:49 PM
    No body share the KDSS beware thread :dancingbacon:
    Thacrow and Thatbassguy like this.
  21. Jul 3, 2023 at 8:53 PM
    It certainly looks like an improvement from the current version. But, you'd have to be a fool to think it will outperform the next Prado, which will most likely have KDSS, as the new GX's "Overtrail" trim does.
    Captain Spalding likes this.
  22. Jul 3, 2023 at 9:00 PM
    The potential for failure is always worth considering.
    But, I think a bigger consideration is that, even though provides an advantage for stock, or lightly modified vehicles, it eventually becomes a limitation.
    Anyone who's planning heavy suspension modifications should probably skip it.
    kmeeg[QUOTED] likes this.
  23. Jul 3, 2023 at 9:05 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Should be way better than both.
    New tacoma has much larger tires than the prado. Larger tires are the single best thing to improve 4wheeling capability.
    Regarding the GX....it has lower profile tires. It also has worse entry, departure and breakover angles than the 2024 tacoma. So yeah I think the taco will be better off road if all these are stock. Taco also has 1.5 inches more ground clearance.
    Why would toyota spend their time making luxury vehicles better off road than anything else they produce when the people buying them aren't going to be taking them off road as much.
    GX is also 8 inches wider and 2 inches taller. My 4runner has barely fits on many a trail. The GX wouldn't be able to fit in as many places. Not as good
  24. Jul 3, 2023 at 9:16 PM
    33 inches is much larger than 33 inches?
    Also, the Tacoma TRD Pro, and the GX Overtrail will both have 18-in wheels.
    And , the GX's approach, break over, and departure angles are not that much different than the Taco's. And, that's based on the Tacoma TRD Pro, and I'm not sure which GX trim. But, it's possible that the Overtrail trim will have different numbers than I found.
    We'll see what happens, though . A lot of people are speculating that the Prado will be Toyota's answer to the Bronco, so I expect it to have better specs than the GX, regarding off-road capability.
  25. Jul 3, 2023 at 9:34 PM
    Not on the same subject but I feel like with tire size 265/70R18 SL Toyota might be not true about 33in tire marketing. It also might not provide any side wall advantage compared to our stock tires. Not just, just kept bothering my brain.
  26. Jul 3, 2023 at 9:41 PM
    According to Tiresize.com, that calcuates out to 32.6", so not a true"33.". Then again, a lot of 33's aren't exactly 33", anyway. :notsure:
    5six likes this.
  27. Jul 3, 2023 at 9:46 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I found 265/65 R17 for the prado.
    The difference in stats are significant.
  28. Jul 3, 2023 at 9:48 PM
    That's the size my 2003 4Runner had. What year Prado are you looking at?
    You might want to do a little bit more research...
    Edit: And, I should, too. I'm seeing a few different sets of approach, break over and departure specs. And, it's way too late for me to dive into a rabbit hole right now!
  29. Jul 3, 2023 at 9:49 PM
    At least both 285/70R17 and 255/80R17 have many 33 or more options right? Not sure if thats same about 265/70R18.
    Maybe its just me looking very suspicious about Toyota after all the new engines coming out so looking every item in a suspicious mindset. Anyways not relevant for this topic. I might get in trouble discussing this.
  30. Jul 3, 2023 at 9:51 PM
    I haven't looked into it much, but I wonder if there are more tire options altogether by going to an 18- inch wheel? Otherwise, I really wish they would have stuck with 17s.
    Old Tanker and kmeeg[QUOTED] like this.
