Connecting BOTH antennas to an aftermarket headunit **pictures**
Discussion in 'Audio & Video' started by ramonortiz55, Jul 31, 2015.
  1. Jul 31, 2015 at 9:25 PM
    ramonortiz55
    ramonortiz55 [OP] New Member
    Ramon
    So when I installed my aftermarket radio, I noticed a loss of AM signal on my radio. YES, I listen to AM radio. So shut it!
    After doing some research, it came to find out that the 4runner has TWO antennas. One for FM, and a booster for AM that runs towards the back.
    Other's say that the booster in the back is for FM also. Regardless, I wanted to use that "booster" antenna to improve my AM reception.
    Since the aftermarket headunit only had connection for ONE antenna, I had to find some sort of adapter to go from two antennas, two one antenna.
    After doing some research I found a Y adapter, and an scosche adapter for the smaller antenna plug:
    On Amazon theyre found via:
    Metra 40-UV43 Male to Female Motorola Antenna Cable
    Scosche Mda-B Micro/Delco Antenna Adapter Tip
    I took my headunit out. I am not going to go thru those steps since I already discussed it here:
    https://www.4runners.com/threads/installing-aftermarket-radio-and-switch-panel-pictures.627/
    Once I pulled out the headunit, I dug around for the two antenna cables:
    The smaller one is for the rear antenna. The larger one is for the regular whip antenna that I was using to plug behind the headunit. The smaller antenna uses the scosche adapter before plugging it into the Y adapter.
    I then plugged the Y adapter into the back of the headunit.
    Voila! AM reception is now improved!
    zteymoorian likes this.
  2. Nov 11, 2020 at 11:13 AM
    Shurong99
    Shurong99 New Member
    2003 4Runner v8 limited
    I installed the double din from Amazon didn’t any am radio reception. After I saw your post I found the item male antenna cable but I can’t find the adapter tip . Which tip I can use it because I click on it it said doesn’t fit the 4Runner. Can u tell me the adaptor tip you have ordered
  3. Nov 11, 2020 at 11:33 AM
    If it makes you feel any better I need to listen to AM for football games on my way home from work.
    because of the damn time difference radio is all I got.
  4. Apr 16, 2022 at 11:37 AM
    zteymoorian
    zteymoorian New Member
    Thanks so much! This post was incredibly helpful! I appreciate your time and effort.
