Comments on oil leak
Discussion in '3rd Gen 4Runners (1996-2002)' started by thepipewerks, Nov 17, 2023.
  1. Nov 17, 2023 at 12:34 PM
    thepipewerks
    thepipewerks [OP] New Member
    My son's 2001 4Runner was leaking oil. Took it to a reputable mechanic and he stated that in order to address the leak, they would need to do a motor drop and full reseal. The vehicle has over 229K miles on it. Prices are all over the board, but the question is, "is it worth it?" or "is it time to retire the vehicle"?
    Based upon some of the comments I've already seen, the potential cost (labor) is between $1,700-$2,000, plus parts (which are not known, although it would be nice to simply assume minor gaskets, etc). Thank you
  2. Nov 17, 2023 at 12:50 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Two most common areas are valve covers and rear main seal.
    Take that back, the rear main isn't as common for leaking but is the only leak that warrants some real labor.
    At that mileage, I suspect it'd be the valve covers. I've had two 5VZ's (Tacoma and 4Runner) and only one dripped oil at the valve covers and the other was leak-free.
    The leak wasn't even bad enough to hit the ground as it would just burn off on the exhaust manifold.
  3. Nov 17, 2023 at 1:14 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Did your mechanic identify exactly where the leak was coming from? Sounds like your mechanic wants to just replace all the gaskets which is probably not a bad idea. Car prices are still through the roof now so if it runs well you couldn’t get another vehicle for what it’s going to cost to do this work. Good luck. Keep us posted on how you make out.
  4. Nov 17, 2023 at 1:19 PM
    Worth it is only something you can answer.
    KBB is $4kish for it.
    Repairs going be over half what the 4R is worth.
  5. Nov 17, 2023 at 1:29 PM
    thepipewerks
    Some really good replies. At this point, he (son) only needs it to last until he finishes high school this year and then maybe until July-August 2024 and then he's off to college. If he can last that long, then it appears as though just continuing to feed the oil is the best solution. Thank you all.
  6. Nov 17, 2023 at 1:42 PM
    Oakboro, N.C
    If they are able, Have them put some dye in the oil and then nail down exactly where/what is leaking.
    Possibly, something minor that could be repaired and save from the full Monty.
  7. Nov 17, 2023 at 2:02 PM
    How much oil we talking?
    If its little bit I say run it since it only gotta last less than a year.
