Cold air intake
Discussion in '5th Gen Builds (2010-2024)' started by ToyotaRDie, Sep 16, 2021.
  1. Sep 16, 2021 at 1:01 PM
    ToyotaRDie
    ToyotaRDie [OP] New Member
    Has anyone who installed a CAI have the "check engine" light come on?
  2. Sep 16, 2021 at 1:05 PM
    Assuming you did so check all the connectors and hoses are put back.
    Also depending on what you bought hope filter wasn't drenched in oil or sensors may need cleaning.
  3. Sep 16, 2021 at 1:09 PM
    ToyotaRDie
    Yes, double checked all that. Just wondering if others have had this issue.
  4. Sep 18, 2021 at 12:06 PM
    Wyzguy2001
    Wyzguy2001 New Member
    2021 4runner trd or
    None yet but coming
    I just installed the toyota trd CAI. No issues.
    ToyotaRDie[OP] likes this.
  5. Oct 2, 2021 at 1:01 PM
    TacoTheTaco
    TacoTheTaco New Member
    On my Tacoma, I had this problem because one of the hoses wasn’t fully seated. Made sure I avoided this with the 4Runner and what a PITA. I’d recommend making sure all of the hoses are secure, could be as simple as air getting in somewhere after the sensor.
  6. Nov 26, 2021 at 7:19 PM
    Bear76
    Bear76 New Member
    2022 Runner SR5 Premium+
    Still sitting on a cargo ship
    Hi! Brand new here. Will post up in Introductions when the new ride gets here. (It’s in a boat off NY at the moment)
    My 2016 Tundra throws the check eng whenever I install the High Flow filters. It’s a P0101 and basically means your MAF is registering too much air. Not sure if the same code is being tossed by the 4R, but I’ll make the assumption that both ECU’s are based off similar diagnostic schedules.
    I run a scan gauge in the Tundra to see/check/clear these codes on the fly, plus I can see live Tranny temps.
    Not sure if that helps or not.
