Colby valve stem TPMS
Discussion in '5th Gen 4Runners (2010-2024)' started by SmithJ, Sep 7, 2024.
  1. Sep 7, 2024 at 3:04 PM
    SmithJ
    SmithJ [OP] Not a New Member
    What type of tpms sensor does a 2020 sr5 have, and will the Colby work as a emergency replacement for the valve stem?
  2. Sep 7, 2024 at 10:32 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    I don’t know for sure, but I would think worst case you would jam a screwdriver in there and bust the double sided tape holding the TPMS. I carry two Colbys but never used them yet.
  3. Sep 9, 2024 at 10:45 AM
    SmithJ
    Any other thoughts?
  4. Sep 9, 2024 at 10:54 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    The sensor is not mounted with double sided tape. It is a nut and sleeve.
  5. Sep 9, 2024 at 11:26 AM
    SmithJ
    Does it keep you from using a Colby stem?
  6. Sep 9, 2024 at 11:33 AM
    2020 4Runner
    Fl
    To get the sensor out, the tire bead has to be broken loose from the wheel.
  7. Sep 9, 2024 at 11:40 AM
    SmithJ
    Well, that certainly cancels out any usefulness of the Colby stems, doesn't it.
  8. Sep 9, 2024 at 11:46 AM
    The Colby can still work from what it looks like. I've never used it but I did just change my TPMS on my own. If this video is really how it works then you should be ok.
    https://www.youtube.com/watch?v=exCyvRVXb2M
    You will just have the sensor banging around the rim until you can get it out.
  9. Sep 9, 2024 at 11:55 AM
    SmithJ
    So you would just take the outer nut off the TPMS, push the stem in, insert the Colby and leave the inner part of the TPMS loose in the tire till you can get somewhere to remove and repair the tire? That sounds ok in an emergency.
  10. Sep 9, 2024 at 11:58 AM
    Yes just remove the nut. I think it was a 10mm but if it breaks guessing pliers or something will have to do its not on there super tight.
    And just push whatever is left of the stem into the tire. It will just be banging around in there. The sensor part in the tire isn't held on to anything the nut holds it in place.
    SmithJ[QUOTED][OP] likes this.
  11. Sep 9, 2024 at 12:17 PM
    SmithJ
    Thanks for the info
  12. Sep 9, 2024 at 12:51 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Do you think the sensor would break if it was loose in the tire for a little bit?
  13. Sep 9, 2024 at 12:54 PM
    I would replace it. It might work for a little while but who knows.
    But I do know these work. This is what I used when I did the TPMS on my own in my Tacoma. If you want cheap.
    https://www.amazon.com/dp/B0CLY13Z3J?ref=ppx_yo2ov_dt_b_fed_asin_title
    Breaking the bead on factory tires isn't so bad. But I can imagine it being painful with LT tires.
  14. Sep 9, 2024 at 1:03 PM
    3JOH22A Toyota Gigolo
    Yes, plan/budget for the sensor to be destroyed if you push it into the wheel.
    You can break the bead with the bottle jack, remove the sensor, then pop the bead back on with a flammable aerosol. However, this is slower than swapping in your spare tire.
    Spare Parts[QUOTED] likes this.
  15. Sep 9, 2024 at 1:07 PM
    I found using a scissor jack was better.
    My bottle jack would max out before the bead would pop. I figured using 2x4 under the tires or something was more of a pain in the ass than just using a different jack.
    I also saw a guy using a 4x4 and he drove another car up it to break the bead.
  16. Sep 9, 2024 at 1:08 PM
    SmithJ
    But if the valve stem is damaged enough that you have to replace it with the colby (in an emergency) then you would need a new sensor anyway, right? Since they appear to be one piece?
  17. Sep 9, 2024 at 1:17 PM
    Yes pretty much. The stem is solid so if you ever broke that you need to change the whole thing.
    SmithJ[OP] likes this.
  18. Sep 9, 2024 at 2:57 PM
    2020 4Runner
    Fl
    It depends on the model year. The 2020 and newer are a little different....same on the Tundra side. The newer models don't like most aftermarket sensors.
