Coil spring for Bilstein 4600
Discussion in 'Suspension' started by mrwpg, Oct 13, 2024.
  1. Oct 13, 2024 at 4:07 PM
    mrwpg
    mrwpg [OP] New Member
    2007 Toyota 4runner SR5
    llo everyone,
    I recently purchased a set of B4600 rear shocks for my 2007 SR5. The front shocks are Monroe front quick-strut and were changed not too long ago. I'm now considering replacing the rear coils as well when I take the vehicle to shop for rear shock change and am currently looking into the Moog-81045 and Bilstein B12 (36-281817). However, I'm unsure which would be the better choice, or if there's another option available that won't cause a height imbalance with the front and isn't more expensive than the Bilsteins. I would appreciate any advice or recommendations!
    Thank you!
  2. Oct 13, 2024 at 6:37 PM
    Welcome to the forum, someone will be able to help you out soon.
    mrwpg[OP] likes this.
  3. Oct 14, 2024 at 3:53 PM
    TrailSpecial22 New Member
    PA
    that rear spring will give you a 1” lift increasing your rake
  4. Oct 14, 2024 at 5:43 PM
    mrwpg
    I use the vehicle for city driving. Will the lift give me any benefit? Or should I stick to a spring with no lift? Also will the 4600 shock support the lift without any issues? Thanks!
  5. Oct 14, 2024 at 6:10 PM
    PA
    im not sure about the 4600 shock but I know the 5100 for the rear supports 0-2” lift springs in rear
