Codes 24 and 32 and sunroof doesn't close flush
Discussion in '2nd Gen 4Runners (1990-1995)' started by Brix&Filip, Jan 6, 2020.
  1. Jan 6, 2020 at 2:58 AM
    Brix&Filip
    Brix&Filip [OP] New Member
    1991 Toyota 4Runner SR5
    Hi, new to this forum, hope you guys can give me some advice. I purchased a 1991 4Runner with 49.5K on it. Cleanest truck I've seen. Slept in a garage with a cover it's entire life. However truck start but engine has no power. Bought it "As Is". I have codes 24 and 32 on the OBD1 (Flow Meter??). I opened the sunroof and now it doesn't close flush to the roof and the sunroof cover it's broken. I paid 6K cash for it, don't know if I paid too much or not...love the spare tire mounted on the tailgate. Please, if someone have the sunroof cover in blue or at least the part number, let me know, willing to buy. . Thanks a lot for any help that you guys can give me !!4Runner Cluster.jpg 4Runner Engine.jpg 4Runner Spare Tire.jpg 4Runner Tailgate.jpg 4Runner RH Side.jpg 4runner Radio.jpg
  2. Jan 6, 2020 at 3:08 AM
    WallyT4R
    WallyT4R New Member
    Welcome! :thumbsup:
    Wow that is a great find. Things on that vehicle have not been used for years so you are going to have some things go wrong. You can look up the codes on line. Hope you get it figured out and running great.
    Here is a thread related to your codes. Also has a link to the FSM which you will need.
    https://www.yotatech.com/forums/f116/toyota-22re-code-24-31-a-212069/
    4Runner fun and SlvrSlug like this.
  3. Jan 6, 2020 at 8:19 AM
    Welcome.
  4. Jan 6, 2020 at 9:23 AM
    welcome
  5. Jan 6, 2020 at 11:03 PM
    4runningMan
    4runningMan New Member
    New Mexico
    More photos when you get it outside please!! And welcome to the forum!
    Was the tire on the tailgate a mod or OEM?
  6. Jan 6, 2020 at 11:06 PM
    WallyT4R
    WallyT4R New Member
    I believe it's OEM on foreign 4's. Not those gens in the USA. But may be wrong
  7. Jan 7, 2020 at 4:10 PM
    Brix&Filip
    Hi,
    Thanks for writing. Will post more pictures asap. The spare tire carrier is OEM and truck is US spec's. I believe it only came in some Second Generation SR5 4X4 models but not sure. As a matter of fact that's what I liked about the truck. Thanks for writing
    WallyT4R likes this.
  8. Jan 7, 2020 at 4:47 PM
    4Runner fun
    Ryan
    Nebraska
    Congratulations on the find & welcome from Nebraska!
    What is under the rear floor if there is no tire there, just a empty space?
    Very clean truck. Congratulations again!
  9. Feb 10, 2020 at 1:03 PM
    92T4R
    92T4R New Member
    I may be a little late to rep,y.
    Don't be discouraged with the T4R. It looks vey nice.
    It's a Toyota, you will get it running. Don't sweat the little stuff.
    That looks like a nice truck!
  10. Feb 11, 2020 at 4:14 AM
    Fourtoad
    Fourtoad Gatorgrl's Yotas
    Gatorgrl
    SWFL
    1991 V6 5 speed super clean, Black and grey
    Stock with headers and after market wheels.
    There are 2 plastic cables with little plastic trucks that operate the sunroof. One of ours was broken. Went to Toyota to get a replacement and was told they do not make them anymore and there are none in stock. :( Ours also leaked due to this fact. :annoyed: So we did the only thing we could do, forced it into position and put braces in to hold it up and in place them put 2" black vinyl tape all along the seam and so far it is water tight. Sure it doesn't open, but it's not leaking anymore either!
  11. May 11, 2020 at 3:43 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Yea, nice find with 50K on the odo that is unreal but yikes $6K. Ditto on the sunroof or moonroof. Mine is blocked up with some wood pieces to keep it flush and quiet when going >80 MPH. Damn thing broke on the way home from San Diego right after I had purchased it from a listing on Craigslist 2-1/2 years ago. Mine was 232K and $1,600 and now I'm one engine rebuild later that cost about $2K and am very pleased with this vehicle as it will purr at 3,500 RPM all day long with plenty of throttle left for inclines and gets 16 MPG on the highway.
    Welcome to the club!
    Fourtoad likes this.
