Clunking noise under front left side
Discussion in '5th Gen 4Runners (2010-2024)' started by rebelhackett, Jan 13, 2025 at 2:57 AM.
  1. Jan 13, 2025 at 2:57 AM
    rebelhackett
    rebelhackett [OP] New Member
    Monday
    kevin
    2018 4runner
    none
    My 2018 4 runner limited has a clunking noise that sounds and feels like it is right under drivers seat or left front side. I have greased and inspected all u joints , changed front and rear diff. fluid and transfer fluid. The fluids all looked good and even emptied the fluid in a clean container through a paint funnel strainer to look for any metal. Weird thing is, the noise isn't always there. I could drive it for weeks and it will never make any noise and other days it sounds like something is falling apart. I have to pull over and back up and most the time the noise stops. I do hear the needle bearing in the front diff. humming when its cold. Its sounds like a bad u joint but I took the front drive shaft off and the u joints all feel good. I also tried driving it without the front driveshaft and the car wont drive because it is all wheel drive. Has anybody else had this issue?
  2. Jan 13, 2025 at 3:10 AM
    Welcome from Wisconsin!
  3. Jan 13, 2025 at 3:11 AM
  4. Jan 13, 2025 at 6:39 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    What's your mileage?
    Last clunk like this I had ended up being by upper control arm upper ball joint. Felt like it was directly under my seat... Every time I turned right I'd get a severe clunk. Jacked up the rig and was able to move the wheel quite a bit more than normal. Then saw excessive play in that UBJ.
    That said, these were aftermarket joints (SPC) and I wouldn't anticipate the stock ones failing for at least 80,000 miles unless they went through some hard use.
  5. Jan 13, 2025 at 8:00 AM
    When does the noise happen? Under what circumstances?
    BTW, the Limited do not have the needle bearing noise issue, as that noise only happens when the axle is being turned but not driven. The Limited axles are always driven.
  6. Jan 13, 2025 at 8:44 AM
    Number16
    Number16 New Member
    2021 4runner
    That's good to know.
  7. Jan 15, 2025 at 12:23 AM
    rebelhackett
    Monday
    kevin
    2018 4runner
    none
    Thanks. It only has 61,000 miles. It makes noise when the car is in motion even it I put in neutral and coast down a hill. Sometimes it feels and sounds like the transfer case and other times the left front wheel.
  8. Jan 15, 2025 at 5:41 AM
    1SilverRunner
    Tejas
    One thing to check is your LCA bolts. My buddies was clunking the other day. Just needed to be retorqued a voila
  9. Jan 15, 2025 at 5:54 AM
    rebelhackett
    Monday
    kevin
    2018 4runner
    none
    Thanks I will check them, but it seems like it is something that is turning like axle, transfer case or drive shaft. Which I don't feel or see anything wrong with u joints. Also the noise is't always there but when it is there it sounds and feels like something is falling apart.
