Clicking noise and wheel shaking
Discussion in '5th Gen 4Runners (2010-2024)' started by adlersmith, Dec 18, 2024.
  1. Dec 18, 2024 at 12:28 PM
    adlersmith
    adlersmith [OP] New Member
    Adler
    2019 black trd off road premium
    I went off roading today and was drifting around in the mud and everytime I do it my traction control turns on and starts making a clicking noise and locking up my wheels and every time I reached up and turned it off it would turn back on
    Once I was done I got back on the road and my wheel started shaking back and forth a lot
    can anyone help me with these two problems
  2. Dec 18, 2024 at 12:38 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    There is likely mud stuck in your wheels and tires causing them to be off balance.
    To disable traction control and stability control come to a stop first, then hold the traction control button for you few seconds. You'll get a prompt on the dash that these systems are disabled. Now you're free to have some fun.
    Toy4X4 likes this.
  3. Dec 18, 2024 at 12:53 PM
    adlersmith
    Adler
    Ok I will go give it a good spray down
    I would stop and turn it off then it would turn itself back on is that normal ?
  4. Dec 18, 2024 at 1:13 PM
    1SilverRunner
    Tejas
    Yes its normal. When you press the button it just disables traction control for a few seconds. It does not disable stability control. Because your stability control was still on your rig was applying braking force to individual wheels to keep you from sliding. This is what you were hearing and feeling.
    To disable both safety features, come to a stop and hold the traction control button for a few seconds. Youll get a prompt on the dash letting you know when theyre disabled.
  5. Dec 18, 2024 at 2:53 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Do you have the owner's manual? If so, it's probably time to read it. As for the shaking, it's mud caked on the inside of your wheels. Wash them well.
    Toy4X4 likes this.
  6. Dec 18, 2024 at 6:00 PM
    scanny
    scanny New Member
    Ontario, Canada
    I think if you turn off traction control it turns itself on when you reach certain speed. Should be in manual.
  7. Dec 19, 2024 at 11:45 AM
    adlersmith
    Adler
    I washed it out really good with a power washer and I am pretty sure I got all the mud off the wheel and suspension but it is still shaking. Is there a chance I lost a couple weights and if so would that make it shake ?
  8. Dec 19, 2024 at 12:51 PM
    TC on dash still come on?
    Could of damaged a sensor and it keeps kicking on when it doesn't need to.
  9. Dec 19, 2024 at 1:24 PM
    1SilverRunner
    Tejas
    I need to read that manual again...
    I thought it just kicked off after a few seconds. But this makes more sense since a lot of other systems turn off around 7mph. I'd imagine traction control is similar. Thanks!
    At least Toyota gave us the option to disable them completely. 4WD donuts in the snow are a hoot!
