Cleaning Radiator and Condenser Fins - How To
Discussion in '5th Gen 4Runners (2010-2024)' started by JackBear808, Jun 24, 2024.
  1. Jun 24, 2024 at 10:46 AM
    JackBear808
    JackBear808 [OP] New Member
    2015 Red 4Runner Trail
    Eibach Pro-Truck Coilover Stage 2R, JBA UCA's, Method M705, Falken A/T4W
    Is there a procedure anywhere to gain access to the condenser and radiator fins to clean them? Seems like this should be a routine maintenance thing but I am having trouble finding any results on Google.
  2. Jun 24, 2024 at 11:00 AM
    Spray through the radiator with a hose. I use pressure but it's set low.
    JackBear808[OP] likes this.
  3. Jun 24, 2024 at 5:34 PM
    JackBear808
    Do you bother trying to remove the radiator fan shroud or just spray through that?
  4. Jun 25, 2024 at 11:44 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Remove the lower splash shield that connects to the skid plate and you will have lots of access.
  5. Jun 27, 2024 at 9:08 AM
    JackBear808
    I was experiencing poor A/C cooling in traffic and at idle.
    I checked the R134a pressure and it was good, so I assumed the airflow to the condenser via the fan was meeting resistance from clogged cooling fins.
    Here is what I ended up doing to get in between the condenser and radiator and wash away the dirt and built up cottonwood seeds that were covering the cooling fins.
    You need a stubby host sprayer like this
    Remove the skid plate, filler plate, and radiator support covers to have full access to condenser and radiator.
    Loosen the radiator top bolt and bracket support bolt on both sides of the radiator.
    Also remove the 3 bolts for the coolant overflow tank, and the 1 bolt for the fan shroud on that side.
    Now the top of the radiator can move out of the bracket and can expose about a 1" gap. You can see in the picture there was alot of build up.
    I first sprayed through the gap to loosen as much of the debris off and washed it downwards.
    Then I sprayed through the fan shroud and tried to get all areas. You can see the water flow all the way through to the front, effectively back flushing.
    Followed that up with spraying from the front of the condenser, and finally a second rinse through the gap.
    I left the hood open and it all dried up in a couple hours. Reassemble and you're done.
    ualfltdispatch likes this.
