Check Engine/Trac Off ob
Discussion in 'New Member Introductions' started by Bbul, Mar 2, 2024.
  1. Mar 2, 2024 at 9:05 AM
    Bbul
    Bbul [OP] New Member
    2014 4 limited
    1st time poster…
    Original owner of a 2014 4Runner limited. About 2 or 3 years ago (during COVID when car sat for extended periods) I noticed my the vehicle would not illuminate the D when in drive on the dash. I can go thru P, R, N but blank for D. After driving for a few minutes, the check engine and Trac Off would come on. Checked the gas cap and it only appears to happen when the car sits for more than a day. The car runs fine but a little tough shifting from park to drive. Typically after a continuous driving the lights will go out and the D appears on the dash when in drive. Had the dealership and a local mechanic have a look and I never received a satisfactory response or fix. Any recommendations on how to solve this for once and for all? Thanks.
  2. Mar 2, 2024 at 3:58 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome,
    first move I would suggest is finding out if the is any malfunction codes stored in the computer
  3. Mar 2, 2024 at 3:58 PM
  4. Mar 2, 2024 at 6:23 PM
    DesertSurfer
    Welcome to the forum, good luck with the Gremlins.
  5. Mar 3, 2024 at 3:44 AM
    Welcome from Wisconsin!
  6. Mar 3, 2024 at 7:23 PM
    Startrek
    Startrek New Member
    No gremlins there. Transmission selector switch went bad. Use wheel brush to clean trans switch shaft and PB to slide switch off without damaging shaft.
  7. Mar 3, 2024 at 7:38 PM
    Startrek
    Startrek New Member
    And check for "green" corrosion inside switch plug.
