Check engine code P2441
Discussion in '4th Gen 4Runners (2003-2009)' started by jlb3232, Mar 30, 2021.
  1. Mar 30, 2021 at 5:57 AM
    jlb3232
    jlb3232 [OP] New Member
    2005 4.7L Silver 4Runner
    I’ve just done new brake lines and aftermarket radio
    Hey guys! I’m new on here because I’m a brand new 4Runner owner and had a question. The CEL went on and also threw the TC and VSC light along with it. After scanning it I got the P2441 code with the secondary air injection pump. I’ve done a ton of research and turns out it can be so many different things that are causing the code. Do I replace the pump or the valves myself? I also hear it can be a hole in the manifold or even the wiring and I’m not sure if I’ll get in over my head if I try and replace it myself. Just need some advice on what to fix myself to try and save some money or if I just take it to be figured out at Toyota or my mechanic.
  2. Mar 30, 2021 at 8:26 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Welcome!
    It could absolutely be a number of things you already listed, and you can have a mechanic test everything to verify or do it yourself. Or, check out this kit https://hewitt-tech.com/store/index.php?l=product_detail&p=82 to bypass it. Many threads exist on how you can try to figure it out yourself, but there are just as many positive outcomes from just getting this. Hope you figure it out!
