Cheapest diff and transfer case fluid for 2020 SR5
Discussion in '5th Gen 4Runners (2010-2024)' started by Yoytota, Mar 24, 2022.
  1. Mar 24, 2022 at 8:36 PM
    Yoytota
    Yoytota [OP] New Member
    FL
    SR5 4X4
    What's the cheapest transfer case and differential fluid I can get for a 2020 SR5 that won't void the warranty?
  2. Mar 24, 2022 at 8:51 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Corn oil
    Maybe peanut oil in 5 gal jug
    a47chuck, BionicRandy and 7385 like this.
  3. Mar 24, 2022 at 9:11 PM
    This is a general question not directed at the OP, why do some people insist on saving a buck when it comes to purchasing lubricants that are essential for protecting very expensive components such as engines, transmissions and gear boxes?
  4. Mar 24, 2022 at 9:21 PM
    MAG 1, I got it cheap from the Toyota parts department.
    Yoytota[OP] likes this.
  5. Mar 25, 2022 at 3:55 AM
    Yoytota
    FL
    SR5 4X4
    I called and they said $65-$90 a quart. I asked if that was TRD oil he said no just Genuine Toyota
  6. Mar 25, 2022 at 4:16 AM
    Supertech at Walmart, in the appropriate grade. I believe it's 80/90, but don't quote me.
  7. Mar 25, 2022 at 5:05 AM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    SuperTech synthetic 75w90 at Wally World is around $8/ qt. I run it in both my 4Runners.
  8. Mar 25, 2022 at 6:14 AM
    Yoytota
    FL
    SR5 4X4
    How many miles are you getting out of the super tech synthetic in the differentials and transfer case? I imagine that should hold up fine for 50,000 mi with occasional 3,500lbs towing and off-road 4x4 use.
  9. Mar 25, 2022 at 6:33 AM
    Anything off the shelf of the correct viscosity and requirements will work. Kendall, Supertech, Amazon Basics...
  10. Mar 25, 2022 at 6:39 AM
    I think @whippersnapper02's comment addresses your question.
    Often times people think more expensive = more protection. Not necessarily true.
  11. Mar 25, 2022 at 6:44 AM
    Yoytota
    FL
    SR5 4X4
    Problem is nobody knows what the hell the equivalent is for Toyota's proprietary TOYOTA Genuine Transfer Case Gear Oil LF 75W 1 Litre 08885-81080. I'm not taking it to the Toyota service department and paying them $600 to replace the fluid in my diffs and trans case just because they want to use proprietary oil. And I'm not paying $90 a quart for anything much less genuine Toyota transfer case oil.
  12. Mar 25, 2022 at 6:48 AM
    Yoytota
    FL
    SR5 4X4
    My solution is I tore that page out of the manual and replaced it with a handwritten version that says any 75/85or90 gear oil without limited slip additive will work fine for the diffs and trans case.
    Trail Runnah likes this.
  13. Mar 25, 2022 at 6:51 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    Here you are, this is what I use: https://www.redlineoil.com/mt-lv-70w75w
  14. Mar 25, 2022 at 7:11 AM
    Yoytota
    FL
    SR5 4X4
    Looks like that should work I'll try to figure out if they have one that's compatible with Toyota DIFFERENTIAL GEAR OIL LT GL-5 75W85 , 08885-02506 as well
  15. Mar 25, 2022 at 7:26 AM
    That doesn’t sound right. I pay around $7 a quart for genuine Toyota 0-20 at dealership.
    case is 6 qts
    Yoytota[QUOTED][OP] likes this.
  16. Mar 25, 2022 at 7:43 AM
    Yoytota
    FL
    SR5 4X4
    Only if it's genuine Toyota corn oil or peanut oil
  17. Mar 25, 2022 at 7:44 AM
    Yoytota
    FL
    SR5 4X4
    I don't know. I called three different dealers and got three different responses recommendations lol
  18. Mar 25, 2022 at 8:24 AM
    TN_FunRunner
    Jay
    W. TN
    I change it every 40-50k and it’s clean. Haven’t had a issue with it.
    In my 5th gen I do run Royal Purple synchromax in the transfer case. But in my 4th gen it gets super tech in Front diff, rear diff, and transfer case. No complaints and easy to find.
  19. Mar 25, 2022 at 10:55 PM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    I use Ravenol 75W comes from across the pond. It is the Toyota equivalent, I get it from the Amazon. Has an awesome tube inside to fill, without the mess and any pumping or funnel. I think it’s approx 25 bucks for the 1 litre. It’s a little more than what’s needed and comes trickling out of the fill.
    Yoytota[OP] and Thatbassguy like this.
  20. Mar 26, 2022 at 1:39 AM
    The oil for the transfer case really is that expensive! To change it every 30-50k starts adding up lol. Like even getting pretty close to transfer case replacement cost after a while.:laugh:
    The 0w20 you mention is motor oil.
  21. Mar 26, 2022 at 3:37 AM
    Yes, sorry, I think we were comparing apples to oranges. I was referring to the engine oil. The OP was referring to transfer case oil? I must have gone off on a tangent.
    I have heard that the transfer case oil is terribly expensive. But I believe 75w85 GL5 is acceptable substitute. That’s what I am going with when it’s time.
  22. Mar 26, 2022 at 3:46 AM
    Matt83
    Matt83 New Member
    Northeast
    BAM Wholesale and OEM Parts Source have the best prices on the drivetrain oil I have found.
  23. Mar 26, 2022 at 2:30 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  24. Mar 28, 2022 at 8:03 AM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    DIRTRCR13 and Yoytota[OP] like this.
  25. Mar 28, 2022 at 6:44 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Got a 5 gallon jug of Lucas 75w-90 full synth GL-5 for $150 shipped to my door last week. Did the wife's car over the weekend, along with the transfer case at $35 for the 3 quarts of GL-4, 7 quarts of 0w-20 with filter change and 3 1/4 quarts of ATF WS. Good news is, I got plenty left over for my Tundra and the next time I do hers again!
  26. Mar 30, 2022 at 8:16 AM
    MAXIM
    MAXIM New Member
    If you put it that way, you don't deserve your 4Runner. J.K. though and there is nothing wrong with saving money. How about getting Best stuff for less money instead of getting Cheap stuff cheap. Search deals online.
