Changing Turn Signal Bulbs
Discussion in '4th Gen 4Runners (2003-2009)' started by rjlocal22, May 19, 2020.
  1. May 19, 2020 at 11:11 AM
    rjlocal22
    rjlocal22 [OP] New Member
    2004 4Runner limited
    My rear right turn signal bulb blinks fast while the front right bulb does not blink at all.
    So I thought changing the front bulb would be easy until I opened the hood and also looked in front of the wheel and I saw no easy way to access the bulb.
    So I am thinking that it must be accessed by prying off the front plastic cover.
    So how do I get access to the bulb?
    I hope its not a $50.00 job just to change a $5.00 bulb.
  2. May 21, 2020 at 2:27 AM
    rjlocal22
    Solved. Being as the bulb assembly is located on the bumper, I had to lay on my back and then saw an opening barely big enough to reach in and remove the bulb and socket. Not easy to do but I was able to manage.
