CEL for misfire, no issues while driving
Discussion in '3rd Gen 4Runners (1996-2002)' started by RoddyRich, Oct 17, 2023.
  1. Oct 17, 2023 at 5:07 PM
    RoddyRich
    RoddyRich [OP] New Member
    97 4runner Limited
    I’m getting an CEL for a misfire. Only time you notice anything wrong is at idle. RPMs have a rhythmic surge from 600 to about 900. Otherwise when driving there is no issue. I have already replaced spark plugs, cleaned throttle plate, checked tps, checked voltage on the coil packs and wires. Ive tried to seafoam the engine but the car ate all of it. No smoke came out after seafoaming. No oil in the coolant and no coolant in the oil either
  2. Oct 17, 2023 at 6:20 PM
    Ahdofu
    Ahdofu New Member
    Matt
    What does the OBD show for misfire?
    negusm likes this.
  3. Oct 18, 2023 at 7:33 AM
    Don't seafoam a modern car. It's not good for it.
    Post the codes.
    When you took out the old plugs, how did they look? Do you still have them?
    Surging sounds like the TPS is bad. I don't know how you can check a TPS reliably. Also check for vacuum leaks.
    Sounds like multiple issues.
