CarPlay Volume Locked
Discussion in 'Audio & Video' started by djd562, May 3, 2024.
  1. May 3, 2024 at 8:04 AM
    djd562
    djd562 [OP] New Member
    DJ
    2024 TRD Pro
    So I have a 2024 TRD Pro with CarPlay. The system worked flawlessly for two months since new, then I started have problems with the volume, where the it would intermittently lock at the last volume I had the radio set at, but I could disconnect then reconnect CarPlay and it would start working again. Over time, the problem happened more often. Now, for the past three weeks, the volume is locked at the same level and cannot be adjusted. The volume is the same no matter what app I’m using. I’ve uninstalled and reinstalled it several times with no success. I posted on two Apple forums and haven’t gotten a response that has worked.
  2. May 3, 2024 at 9:46 AM
    djd562
    DJ
    2024 TRD Pro
    My phone has been updated, rebooted, and still same problem.
  3. May 3, 2024 at 3:38 PM
    garoto
    garoto New Member
    Try a different iPhone to rule out if it’s a car or phone problem.
    Also, remove the Toyota car from CarPlay altogether in the iPhone. And set it up fresh.
  4. May 3, 2024 at 4:04 PM
    icebear Recovered Kia Owner
    There may be a procedure to reboot the head unit itself that’s separate from normal turning the car on/off, I’d try that.
